Old 16th October 2011, 11:52 PM   #1
srinath is offline srinath  United States
Default Is there a chip amp tha twill run @ 110v
I am looking to build something like a 2000 watt subwoofer amp pushing 2 15's in a home made cabinet.
The hardest part seems to be to find a transformer that will supply 2000w at the 40-60v the chip amp needs.
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
I am wondering if there is a chip amp kit where I can use the 110 straight on.
I am using an equipment power/conditioner supply that currently is a 10000w capacity, and I may get a second one if its full to capacity as well as put fuses etc to prevent big blow up's with lightining strikes etc.
Thanks.
Srinath.
Old 17th October 2011, 12:06 AM   #2
jcx is offline jcx  United States
any discussion of direct power line use is Prohibited here - it is simply UNSAFE
get a transformer - then there are chip amps that can be paralleled and bridged for 200 W output
even then the highest supply V cheap option - the TDA7293 can only take 100 V between Vsupply pins
Old 17th October 2011, 12:29 AM   #3
N-Brock is offline N-Brock  United States
N-Brock's Avatar
Antek has several 1500VA transformers in that voltage range and 1500w pre-made power supplies.
Antek - Your reliable source of transformers, power supplies, and more.
Good luck,
Nelson
Old 17th October 2011, 02:18 AM   #4
Default 200 va
Not 200w, 2000w. I'll look at that tda 7293.
Cool.
Srinath
Old 17th October 2011, 06:06 AM   #5
Send a message via Yahoo to Th3 uN1Qu3
2kW from a chipamp is impossible unless you run many of them in parallel - and even then that power will only be achievable on a very low impedance load (certainly lower than 2 ohms). You need a discrete design.
"Audio grade" components simply means that they failed at a more critical job.
Old 17th October 2011, 06:22 AM   #6
theAnonymous1's Avatar
I think the only devices even close to being a "chipamp" that will get you to that power level would be something like the LME49830/LME49811/LME49810.
"If you don't like funerals don't kick sand in Ninja's face." - Ninja
Old 17th October 2011, 07:14 AM   #7
UrSv is offline UrSv  Sweden
UrSv's Avatar
Why not a Cirrus PA52. It does 200 V with 40 A continous out (80 A peak). Could be a good candidate?
UrSv
Those who say it can't be done should not stop those who are doing it.
Old 17th October 2011, 07:36 AM   #8
Yeah, that's practical. A chipamp made out of a >$800 power op-amp? And that would only be one channel!
Old 17th October 2011, 08:19 AM   #9
UrSv's Avatar
Price was not part of the original question
UrSv
Old 17th October 2011, 09:11 AM   #10
Atilla is offline Atilla  Norway
Soldering Gun Fanatic
Sounds like a job for a Class-D powerhouse to me, rather than a chipamp.
Replacement of tha WonderCaps in a Threshold FET/10 Nounours18200 Pass Labs 25 19th November 2010 07:50 PM
looking for 8"woofer tha works in .5 cu/ft3 box rotgg Subwoofers 3 15th February 2010 03:15 AM
How do I convert my 110V B+K amp to run on 220V power? mixersoft Solid State 48 15th September 2009 11:12 AM
Panasonic THA series Electrolytics Mark A. Gulbrandsen Pass Labs 0 15th November 2003 02:19 AM
Page generated in 0.10905 seconds (78.81% PHP - 21.19% MySQL) with 10 queries
