| Chip Amps Amplifiers based on integrated circuits |
hi, finished my lm3975 gainclone and just putting the finishing touches to it. (sounds great btw, with just a few hours burn in)
Want to add a blue led in the amp case (one case is psu, one case is amp). Can i just connect one leg the led to one of the dc power lines going into the chip and the other to the power ground? (with suitable resistors ofcourse) Is it gonna effect the output of the amp, if its only connected to one of the channels? thanks Amit |
#2 |
No it shouldn't make any difference to the sound of the amp, just make sure you get the polarity correct. I guess you know how to calaculate the series resistor? LED SERIES Supply voltage = 24 - operating led voltage ( normally around 3.3 v) Divided by the forward current of the led(50Ma) =24-3.3 /.05= 414 Ohms I used a 1k 2w resistor on mine, as that's what i to hand and it works fine. |
#3 |
yep, thanks.
just tryin to figure out if i have a high enough wattage resistor in the parts box. could i just use p=iv? p = (supply voltage-working voltage) * current draw p = 26-4.5 * 0.02 p= 0.43 W hmm, think i only have 1/4 W resistors about.. |
#4 |
just keep some old pcb's of whatever in the nailbox, should find what you need on them.
#5 |
And for those who are afraid to put a led on the secondary power, there is a small pcb available for a couple of € and you can feed the led from the main power.
if that will affect the sound than everything op to the generator will so it will be out of your control anyway (example conrad partno:184985-44)
better be indoubt untill you're sure |
#6 |
I recall a while back that Peter Daniel and others suggested wrapping additional windings around the outside of a torroidal transformer to create a separate power supply. If this is a viable solution, it would be practically free and unrelated to the circuit.
Just trying to throw something else out there. Sandy. |
#7 |
the resistor wattage is irrelevant as the LED will only be drawing typically 20mA.
the formula is R=(E-Vf)x1000/I where R is the series resistance in Ohms, E is the supply voltage, Vf is the LED's forward voltage (typically 2V), I is the LED current in mA so for a normal, 5mm LED for example, running of +22V you need 1KOhm for an ultra bright blue LED, Vf=3.8V, you need 910Ohms, using 1K is fine. 25V would give 1060 use 1.1 or 1.2K 32V would give 1410 use 1.5K simply use the formula and then the nearest, HIGHER, common value i.e. 800=820, 910=1K, 1100=1200 etc (@10%tol, less tol will provide more divisions and a closer match - but again, that's totally unnecessary) |
#8 | |
We ain't there yet....
Best-ever T/S parameter spreadsheet. http://www.diyaudio.com/forums/multi...tml#post353269 |
#9 |
ummmm... okay.
20-08-2k3= 20th of the 8th (august)=2003 2k=2000 and 3 makes 2003 = 2k3 just like roman numerals really MMI = 1000+1000+1 logical eh? |
#10 | |
Think of the letter like a decimal point . So 2.3 (k=thousand) = 2,300.
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
| Adding an amp | GlennDrodge | Solid State | 2 | 13th August 2009 05:16 AM |
| adding aux's | bodaddy | Instruments and Amps | 10 | 22nd May 2008 05:40 PM |
| adding second HDD to PC | AndrewT | Everything Else | 80 | 5th December 2007 01:38 PM |
| adding DAC to gainclone | ah_fu | Chip Amps | 12 | 24th June 2006 12:46 AM |
| Adding IR to a gainclone? | AJ Bertelson | Chip Amps | 1 | 23rd December 2003 02:36 PM |
| Page generated in 0.10385 seconds (78.23% PHP - 21.77% MySQL) with 10 queries |
