Convection cooling in a GC amp - diyAudio
Old 4th September 2003, 09:31 PM   #1
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Default Never mind the hype, here's the New Amp
Acting on a hint from a custom order and motivated by the discussion on AA forum, I came here with a new design for an integrated GC amp. This time the chassis is made out of wood (of course maple)
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 4th September 2003, 09:34 PM   #2
JoeBob is offline JoeBob  Canada
JoeBob's Avatar
Sweet Jesus, that is a nice amp Peter, really nice.
But do you really need to start another thread that will just be filled with complements directed towards you?
Old 4th September 2003, 09:34 PM   #3
The bottom is containing the circuitry. I also used the ideas from the other thread (waterproof chip) and integrated revolutionary design for heat sinking. The 1" copper pipes are located in ea. corner and using convection method release the heat . The chip itself is mounted to 1/8" copper plate, which is soldered to the pipes. The rest is pretty conventional: BG caps, MUR860 diodes and Nobel pot.
www.audiosector.com
Old 4th September 2003, 09:36 PM   #4
Beautiful as always
Charles
Old 4th September 2003, 09:36 PM   #5
I don't really ask for complements. This is mostly construction design info. Some might not need it, but some others will surely find ispiration
PS: All complements will be moved to trash bin, so save your efforts
www.audiosector.com
Old 4th September 2003, 09:39 PM   #6
Duo is offline Duo  Canada
Duo's Avatar
Send a message via ICQ to Duo
That amplifier is absolutely beautiful. That gives me all kinds of interesting design ideas for inside and out!
Thanks...
-- Duo, W1ngs, VA7MON, and lesser known handles. --
-- http://www.w1ngselectronics.com -- My Work and Projects --
Old 4th September 2003, 09:40 PM   #7
tiroth is offline tiroth  United States
I've often gotten good ideas looking at your work Peter. Thanks!
Old 4th September 2003, 09:41 PM   #8
The transformer is mounted in a top compartment. There is no bolt used here, but the whole space is filled with expandable foam (door and window type). I was hoping that this would reduce possible vibrations. There are 3 acrylic plates between the two maple frames. The pipes are tight fitted in the openings. I used mu-metal shielding under transformer to reduce any intererence.
www.audiosector.com
Old 4th September 2003, 09:46 PM   #9
Here's how it looks when the transformer space is closed. You can notice the small suspended board holding the diodes. It is placed conveniently right above the secondaries wires. You also see solder residue on pipes While soldering, the acrylic didn't really suffer much.
www.audiosector.com
Old 4th September 2003, 09:47 PM   #10
Here's the rear view. The feet were done with the unused parts I had from the spikes, I was using on the other amps.
www.audiosector.com
air cooling karma Pass Labs 8 11th March 2003 04:54 AM
Cooling an amp with poor cooling BAM Solid State 8 31st December 2001 04:40 AM
Copyright ©1999-2017 diyAudio
