| Chip Amps Amplifiers based on integrated circuits |
#11 |
That's very thoughtful of you and is appreciated. Glad you got it working.
One thing that I still don't like the sound of is the "bypassing" of large electrolytic caps with small caps, especially if the small caps are low-loss types like film. Doing that could cause high-frequency ringing or maybe even oscillation. And small-value caps can't do any good when they're working into and through the inductance of the power supply rails that are between them and the point of load, anyway. In a typical linear unregulated PSU, small-value caps are only needed and only useful at the point of load, to short-circuit ("bypass") high frequencies at the power pins that could otherwise form a sneak feedback path and could cause oscillation, and for "decoupling" at the power pins, i.e. to supply the fast transient current demands that can't come through the rails' inductances without causing unacceptable disturbances of the rail voltages, and which couldn't be supplied through the rail inductances with correct timing, anyway. (OK, sometimes they might be needed around the rectifiers, but then you'd probably want to use snubbers, i.e. with resistors in series.) Even in snubbers, where small film caps can also legitimately be used, the resistor is the actual snubber and the cap is ONLY there so that the resistor won't have to deal with frequencies much lower than those that need snubbing, so the resistor won't have to dissipate as much power. In most of the places in a chipamp where you might want a small-value cap, an X7R ceramic (i.e. not low-loss) is usually a much safer bet, and therefore better, than a film type. Last edited by gootee; 28th January 2012 at 02:37 AM. |
#12 | |||||
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
I think ideas are what you want to get rid of. I don't really like songs with ideas. - Leonard Cohen |
#13 | |
A halfwave that starts from nothing and at the other end stops abruptly contains harmonics that theoretically extend out to infinity.
regards Andrew T. |
#14 | ||
Its a very good point and may well be a reason why gootee has suggested a bandwidth around ten times the audio bandwidth. Its also one good reason for why I only design with bridged amps these days
#15 |
I don't think 10times the audio bandwidth is adequate.
That only gets one to 200kHz. I suspect the harmonics >10MHz have an influence on the way a ClassAB PushPull amplifier operates. These are the frequencies that the HF decoupling is supporting (supplying transient current).
regards Andrew T. |
| help setting up idle current | lensmanMk2 | Solid State | 31 | 10th March 2010 11:48 PM |
| Will lightbulb protect my amp from to high idle current at startup? | seafire | Solid State | 5 | 18th September 2009 05:37 PM |
| How to check for low/high frequecy oscillations with a Tektronix 2213A | chris ma | Solid State | 9 | 24th May 2008 02:26 AM |
| High idle current on crown-BCA output? hjelp! | mzzj | Class D | 6 | 28th November 2005 12:01 PM |
| SMPS Idle Current | cm961 | Parts | 2 | 20th February 2004 05:56 AM |
| Page generated in 0.10711 seconds (76.76% PHP - 23.24% MySQL) with 10 queries |
