Old 30th September 2011, 03:07 AM   #1
Default Spice Model TDA2040
Hi
I am about to build some test equipment and was considering using a TDA2040 in the output. My concern was the stability at unity gain. Has anybody a spice model for a TDA2040 or TDA2030? Has anyone tried running these at unity gain?
The idea is to generate a spit supply from a 24 volt plug pack (wall wart to some) so the supply will be +/- 12 volts.
The 12 bit DAC output from a Xmega micro will supply the signal. DC to audio frequencies only. Voltage out +/- 8 maximum. Good output control at mV required so I may have digital gain control (relay Hi Lo).
Regards Ken
Old 30th September 2011, 03:20 AM   #2
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via MSN to abraxalito Send a message via Yahoo to abraxalito Send a message via Skype™ to abraxalito
I created an LTSpice model of LM1876 which is quite similar. Have run TDA2030 at 6dB gain, not totally convinced about the stability yet though - you need to fit a series RC to 'bleed off' some of the excess loop gain.
I think ideas are what you want to get rid of. I don't really like songs with ideas. - Leonard Cohen
Old 2nd October 2011, 12:54 PM   #3
HI abraxalito
Thank you for your reply, it is good to know you have ran one at 6dB of gain. I shall draw up and rout a circuit board making provision for feedback gain adjustment and also a voltage divider on the input. If you are interested I shall report back.
regards
Ken
BTW it has taken me this long to sort out the xmega code as I'm new to the beast.
6sj7 spice model sulcorebutia Tubes / Valves 14 22nd May 2012 04:31 PM
BZX79C12V spice model nicholas1113 Solid State 1 29th December 2009 03:17 PM
2SK373 spice model cs Solid State 1 15th October 2006 12:21 PM
SPICE model Prune Parts 6 16th October 2004 03:22 PM
Spice model doigtee Tubes / Valves 6 12th July 2003 11:42 AM
Page generated in 0.05997 seconds (80.48% PHP - 19.52% MySQL) with 10 queries
