TDA7293 single, bridge, parallel
Old 21st August 2013, 04:52 AM   #91
panson_hk is offline panson_hk  Hong Kong
panson_hk's Avatar
Well, before making a new layout. I should evaluate the amp based on the existing setup. The TDA7293 board layout isn't visually bad to me (at least for TDA7293 used purely as buffer). I check distortion residual to see if there is any induction distortion (described in Self's amplifier book) due to layout or wiring issue.
BW filter 22 Hz to 22 kHz, 8 R dummy load, 1 kHz tone, supply = +/- 25 V
THD = 0.0033 %, 10 W
THD = 0.0065 %, 1 W
Output waveform and distortion residual are shown below. To my knowledge, no sign of induction distortion is seen. Agree?
Old 21st August 2013, 08:33 AM   #92
panson_hk's Avatar
Originally Posted by abraxalito View Post
The second thing I noticed is the input impedance to the buffer (at pin 11) isn't high. I haven't explored this much further, but I wonder if its caused by the current source from the positive supply shown in the internal schematic. About 1.5mA seems to flow from the positive supply pin (pin7) to pin11. I plan to try an equal current source to the -ve supply to mitigate this.
My measurement of current coming out from pin 11 is about 3.0 mA. Two tests were used. One connected 7293 pin 11 to ground via a 1 k resistor. Second connected 7293 pin 11 to LME49811 output (SOURCE+SINK). Two tests gave very close results. As you said, a current source from pin 11 to -V can be used to balance the current instead of sourcing from the driver stage. Is it a good idea?
Old 22nd August 2013, 04:27 PM   #93
aparatusonitus is offline aparatusonitus  Croatia
aparatusonitus's Avatar
Yes, just the switching distortion from TDA7293 output...Could you load a TDA7293 output with an resistor to negative supply rail to force it a bit more to Class A? Start with ~10mA and up, until switching distortion hopefully disappear at 1W output. Watch the TDA7293 dissipation while doing it, and show as your results please.
Non mai abbastanza...
Old 23rd August 2013, 04:54 AM   #94
panson_hk's Avatar
Thank you for your suggestion. This is similar to crossover displacement described in Self's amp book. I can try it later.
I cleaned up the wiring between 49811 driver and 7293 buffer as shown below. Distortion residual of 1 kHz, 10 W, 8 R load was checked for two ground connections of dummy load. One used the 0 V of power supply board. The other used 0 V of the amp board. To fulfill start ground, 0 V at power supply should be used. My AP did not show difference in THD (0.0033 %) of the two grounding points. Distortion residual of the right grounding is closer to "ideal" waveform - purely crossover distortion.
Old 23rd August 2013, 05:22 AM   #95
panson_hk's Avatar
Default LME49811 driver + TDA7293 buffer
Here is result for two 7293 buffer in parallel. 1kHz, 10 W 8R THD was 0.0033 % for single 7293. It reduced to 0.0029 % for two in parallel. Not much improvement under this test condition. Distortion residual is shown below.
Old 24th August 2013, 12:09 AM   #96
As far as I can see from image, at the moment you are using one PSU with dual bridge rectification. If that is correct you should use power ground formed by local decoupling caps near TDA7293 power supply pins as your reference for signal and speaker ground reference.
I'am little suprised to see crossover distortion from TDA's even at low power level...they (invertors) claimed there will be no distortion
Old 24th August 2013, 01:20 AM   #97
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
Crossover distortion is inevitable given the substantial mis-match in gains between the positive and negative 'sides' of the output stage. I am curious how much of the XO distortion is even harmonics? Any chance to see how the distortion residual looks in bridged mode?
<edit> Incidentally I tried playing around with loading down the output stage - this does not appear to improve the distortion as it does nothing to reduce the inherent gain mis-match between the two halves.
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 24th August 2013, 02:18 AM   #98
Kindhornman is offline Kindhornman  United States
Kindhornman's Avatar
Richard,
Why is there an inherent mismatch between sides if you are working in bridged mode with neither side inverting, as in using a buffer before doing the inversion. Is the buffer itself causing the imbalance between sides?
Old 24th August 2013, 02:33 AM   #99
abraxalito's Avatar
Default Output buffer mismatch
Here's the inner schematic from the DS - the top FET M1 is a source follower so its bound to have something less than unity gain. The M2 FET at the bottom is enhanced by the gain of the opamp.
It seems possible that a current source to the negative rail could help to raise the transconductance of the top FET but for reasonably small values of current (tens of mA) I didn't notice a significant difference. Perhaps the currents just need to be much higher.
Old 24th August 2013, 02:44 AM   #100
So is there no way to modify the buffer stage to match the other side so that both sides are equivalent?
TDA7293 single, bridge, parallelHide this!Advertise here!
TDA7293 Bridge Parallel Circuit VikramRaj4ever Chip Amps 36 23rd October 2014 07:34 PM
TDA7293 Bridge Parallel Circuit VikramRaj4ever Chipamp 0 14th June 2011 01:23 PM
My parallel TDA7293 Cro maniac Chip Amps 11 25th March 2010 06:42 PM
parallel, slaved TDA7293 kits - any out there? CharlieLaub Chip Amps 6 21st February 2010 04:43 PM
3 TDA7293 running in Parallel STEVIE Chip Amps 2 7th March 2005 06:57 AM
