| Chip Amps Amplifiers based on integrated circuits |
#21 | |
Bipolar caps are bigger though (but the 16mm diameter helps... ).
Dario ClaveFremen "Bailando Salsa en el Sietch" |
#22 |
The smaller types are called NP, they carry a lower current rating. Actually smaller than the normal electrolytic. I am also thinking about the solidstate caps.
Hear the real thing! |
#23 |
thanks Dario for starting this thread..for me , your design very nice, no problem to attach input caps on board...or direct attach cpas on input connector(rca).
#24 |
If C13 is moved off board, then you don't really need an AC and a DC input pad. With a coupling cap, it's AC. Without, it's DC. Correct? Although two pads would allow connection of both inputs at the same time (with two input jacks) and not take up much space, and let the builder decide. Kind of a cool idea. Perhaps just label both pads DC+ input. Then the jacks (sockets?) on the chassis would be labeled AC and DC. Is that what you mean, Andrew?
I can't think of a cap that's equal to the quality of this amp that will fit onto the space provided, so it's just as well to leave it off. Using a hefty film cap to connect input jack to board is exactly what should be done. I don't know what else that space can be used for, but it would allow relaxation of the somewhat tight spacing of other components that exists now. Perhaps install a mounting hole on that side of the board so builders can physically attach the coupling cap against edge of the board instead of it floating around inside the chassis. I attach mine to the chassis floor with a cable tie, but then I must cut it or detach the cap in order to lift the board. Just throwing out crazy ideas here. Peace, Tom E |
#25 |
Has anyone tried snubbers on the power supply of this amp?
#26 | |||
![]() Quote:
And, probably, the input trace crossing R10 is not a problem at all since since between the trace and the resistor there is the ground plane, which should shield... And that zone is probably the less congested of all the PCB... ![]() Sincerely, I don't think this or the C13 outboard/onboard are high priority problems, first we shoud:
![]() Take a look at the attachment, it could be good? I've also moved a bit the input connector (it was too near to the edge) and used Russ' C13 so the input is a bit farther from the output ground. It's called brain-storming... ![]() It works, usually. ![]() Sorry, this is a taboo...also in the original thread they were proposed upsetting Mauro... BTW who tried them gave different opinions, some heard an improvement, others didn't. Rudi, which realized an alternate PCB called X-Calibre, initially tried them and heard an improvement but after some days he changed his mind.
Dario ClaveFremen "Bailando Salsa en el Sietch" Last edited by ClaveFremen; 25th September 2011 at 03:13 AM. Reason: updated attachment |
#27 |
Sorry, I was wrong, Rudi never changed his mind about snubbers what I was referring to, in reality, is this post in Rudi's X-Calibre thread:
Russ White on snubbers And I do agree with Russ, particularly on the fact that snubbers should be calculated for each different transformer used for optimal performance.
#28 |
I hate to comment on what is "not" audible or not mainly because there are so many factors that influence the results. But the concept of the snubber itself is certainly quite widely used and studied. Some people even use it on diodes. My main interest in this type of amplifier is the relationship between current and voltage, and how it actually shows differences when measuring speakers.
#29 |
Hi Madi,
the C13 as you describe works fine. just an extra phono socket on the back of the amplifier. This requires a hot&return two pin connection on the PCB. The Jens' Leach clone was a bit different. It had a single input socket. The "changeover" was done on the PCB using a shorting plug. This requires a hotAC, hotDC, return, three pin connection on the PCB.
regards Andrew T. |
#30 |
I somehow recall that snubbers are more load transients dependent.
| Hx-Home Edition and Hx Mini Edition will be released December, 24th | destroyer X | Solid State | 51 | 11th January 2012 07:55 PM |
| My_Ref RevO | ClaveFremen | Chip Amps | 52 | 22nd September 2011 06:07 PM |
| ARC Power source+Marantz 7C(PCB edition) | gxcnabin | Tubes / Valves | 35 | 16th April 2011 05:01 AM |
| WTB My_Ref Rev C | nvrgdenuf | Swap Meet | 2 | 29th January 2010 07:37 PM |
| MY_REF technical description | mauropenasa | Chip Amps | 9 | 22nd October 2005 12:59 PM |
| Page generated in 0.13802 seconds (85.62% PHP - 14.38% MySQL) with 11 queries |
