| Chip Amps Amplifiers based on integrated circuits |
#271 | |
reading the datasheets my hypothesis on minimum current seems reasonable. The LM3x7L (TO92 100mA) seems to need at least 5mA of output current while LM3x7T (TO220 1,5A) seems to need at least 10mA. With the 68R value a current of circa 18mA is generated so the margin on minimum current is pretty different. With 50R we can have 25mA, I suppose that it will fill the gap. Maybe also the different origin (Onsemi vs NatSemi) could have a role since the specs are very similar but not identical. A more fair comparison will be the one between OnSemi and NatSemi TO220 1.5A LM3x7s.
Dario ClaveFremen "Bailando Salsa en el Sietch" Last edited by ClaveFremen; 3rd February 2012 at 10:50 AM. |
#272 |
If the harmonics and decay are higher in both dead studio recordings and live hall recordings, then it may mean less fidelity. However, it may be more to one's liking. This is where it gradually becomes difficult to make decisions.
Hear the real thing! |
#273 | |
It shouldn't be difficult to source some NatSemi to compare...right?
Dario ClaveFremen "Bailando Salsa en el Sietch" |
#274 |
What I am going to do with the beta boards first is to give it the same +/- 27VDC that I use now, try to keep as close to your LM318 DC power as possible but put the LM3886 C4 mod in, use the original MyRef values in other components and see how they compare. I just increased the cap size parallel to C4 to 3300uF, further increase triggers the power supply protection circuit on the MyRef but not my other amp (yet). Increased differentiation between hall reflections and instruments make instruments stand out more.
#275 |
Now you are thinking this through.
You have asked yourself "does the change in regulator type, lead to a change in the quality of the regulation?" That question needs an answer and not by ear ! The ear is the evidence that something has changed. The next question should be "what type of regulation parameters suit the amplifier?" and the supplementary question could be "what regulation parameters make the amplifier misbehave?" BTW, the 317 (5mA) and the 337 (10mA) often have different minimum current for specified performance.
regards Andrew T. Last edited by AndrewT; 3rd February 2012 at 11:30 AM. |
#276 |
I think what also needs to be considered is the balance of idle current on the + & - rails for the LM318 chip.
#277 | |||
My goals (in part inspired by Mauro's recommendations on a private e-mail) were:
Since I've got no help for the shunt regulator here I've found it on an italian forum and the FE's LM318 PS is the result. Any help, suggestion or instructive post about it is welcome. ![]() Quote:
Do you think I should expect problems from this difference, it should be compensated and how? Quote:
The LM318 use the needed current, any excess is shunted by both the transistor and the zener. This is not perfect, though, since the possible different amount of current shunted would change a bit the output impedance of the regulator. Any suggestion?
#278 |
Getting to the next step is going to take lots of time in a lab with adequate equipment.
#279 | |
![]() For the Fremen Edition II (one to two years in the future... ) also a completely regulated PS could be interesting. ![]() In the meanwhile it would be interesting to find out if a bigger current for the negative rail would improve performance in an audible way.
#280 |
I have an amplifier with power regulator. Have not compared it lately because it's a really old amp.
| Hx-Home Edition and Hx Mini Edition will be released December, 24th | destroyer X | Solid State | 51 | 11th January 2012 07:55 PM |
| My_Ref RevO | ClaveFremen | Chip Amps | 52 | 22nd September 2011 06:07 PM |
| ARC Power source+Marantz 7C(PCB edition) | gxcnabin | Tubes / Valves | 35 | 16th April 2011 05:01 AM |
| WTB My_Ref Rev C | nvrgdenuf | Swap Meet | 2 | 29th January 2010 07:37 PM |
| MY_REF technical description | mauropenasa | Chip Amps | 9 | 22nd October 2005 12:59 PM |
| Page generated in 0.12733 seconds (83.17% PHP - 16.83% MySQL) with 11 queries |
