My_Ref Fremen Edition - need help on PCB evaluation - Page 15 - diyAudio
Old 12th December 2011, 10:32 AM   #141
Reality first!
ClaveFremen's Avatar
Originally Posted by AndrewT View Post
capacitor (C5) - only to damp ringing.
This does not sound right.
Hi Andrew,
I'm referrring to Mauro's 'Project My_Ref' document:
I condensatori C5 e C22 servono a smorzare i picchi di tensione generati dai diodi, in combinazione con l' induttanza parassita del trasformatore.
Il filtro che si viene a creare (a frequenze di circa 15-30 Khz a seconda del tipo di trasformatore) riduce notevolmente il rumore di rettificazione ad alta frequenza.
English translation:
C5 and C22 capacitors are used to smooth out voltage spikes generated by bridge rectifiers, combined with the parasitic inductance of the transformer.
The resulting filter (at frequencies of about 15-30 kHz, depending on the type of transformer) greatly reduces the high frequency noise.
Can you elaborate?
Maybe it's the term 'ringing' that isn't correct/precise?
Dario
ClaveFremen "Bailando Salsa en el Sietch"
Old 12th December 2011, 10:39 AM   #142
Mauro's description would apply to R+C snubbers correctly applied to the impulsive signals around the rectifiers.
A capacitor alone is not usually suitable for damping ringing/resonances.
It appears from Forum posts and a bit of my own experience that a low loss capacitor is more likely to induce ringing and resonant behaviour. This is the opposite to what you claim (damping).
However, while it appears to me that you are revealing that removing C5 did not make the sound worse, I find your language very confusing. I find your reference to AC input caps and optional AC caps to be completely uninformative & misleading.
No wonder Soongsc had to seek clarification.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 12th December 2011, 10:57 AM   #143
soongsc is offline soongsc  Taiwan
soongsc's Avatar
I do recall there being a paper on snubberizing the diodes. The paper also tried cap across the rectifying diodes, and the performance was not as good. It was not used across the rectifiers like here.
This is a similar paper.
http://www.hagtech.com/pdf/snubber.pdf
I have not put in snubbers for MyRef yet.
I would expect the cap C5 for some power factor adjustments.
Hear the real thing!
Old 12th December 2011, 12:13 PM   #144
I hear quite a few members referring to Power Factor.
Can you explain the mechanism that C5 would play in our comment?
regards Andrew T.
Old 12th December 2011, 12:27 PM   #145
Reality first!
Actually I think that C5 removal is beneficial (in the My_Ref_FE context)
It's true that I could be more clear and I've understood that such terminology was not appropriate, in fact I clarified without problems.
But the wrong terminology doesn't change the facts, or the informative contest of such posts...
I can't understand why you had to point it out...Why in most of your posts I feel a sort of 'negative' energy?
Dario
Old 12th December 2011, 12:53 PM   #146
soongsc's Avatar
I have not pursued this before, but if the transformer secondary has inductive characteristics, using C5 to tune a resonant circuit to the frequency of the mains power should give a better transfer of power where the current and voltage are in phase with each other.
Does this make sense? I'm really trying to apply what we learned in school over 30 years ago. But since I have moved to existing switching power modules, I may not get a chance to play around with these. Having the value that came with the kit probably is just causing resonance at a wrong frequency effecting proper power transfer.
Old 12th December 2011, 12:58 PM   #147
Originally Posted by ClaveFremen View Post
Actually I think that C5 removal is beneficial (in the My_Ref_FE context)...Why in most of your posts I feel a sort of 'negative' energy?
because I read your posts and find my reaction is a shaking of the head. Does that equal -ve? That is not what you said. What you said was
In this moment I'm doing the last tests (LM3886 ground to GND and optional caps for AC input)
Wow
Bass is tighter, soundstage wider and deeper and dynamic gains too, even the output DC offset fall near 0V (from 2mV to 0.5V in one channel).
The AC input caps have also a clear effect
I have trouble understanding some of your conclusions. I have trouble understanding some of the logic leading to those conclusions. I have trouble just trying to understand what you are typing.
Sometimes I have trouble simply believing what you type.
All of this is probably down to me misunderstanding what you type, combined with me not understanding the science behind your experiments.
Yes, it leaves me feeling quite -ve. But, I keep reading hoping that some day I will reach the "I see" moment.
regards Andrew T.
Old 12th December 2011, 01:01 PM   #148
....if the transformer secondary has inductive characteristics, using C5 to tune a resonant circuit to the frequency of the mains power should give a better transfer of power where the current and voltage are in phase with each other.
Not to me. So my answer is "no".
regards Andrew T.
Old 12th December 2011, 01:13 PM   #149
soongsc's Avatar
The original MyRef has the LM3886 GND (Pin 7) referred to 0V (signal ground) while the Fremen Edition to GND (power ground).
The wow is obviously referred to Fremen Edition way.
Well, I just changed the MyRef C channel so that the LM3886 pin 7 connects to power GND. This seems more like what I am used to. But the details are somewhat less, not as much emotion in the music. I may get some time to do some measurements.
Old 12th December 2011, 02:15 PM   #150
soongsc's Avatar
Maximum power transfer theorem - Wikipedia, the free encyclopedia
MY_REF technical description mauropenasa Chip Amps 14 2nd December 2016 12:40 PM
Hx-Home Edition and Hx Mini Edition will be released December, 24th destroyer X Solid State 54 3rd September 2012 03:44 PM
My_Ref RevO ClaveFremen Chip Amps 52 22nd September 2011 06:07 PM
ARC Power source+Marantz 7C(PCB edition) gxcnabin Tubes / Valves 35 16th April 2011 05:01 AM
WTB My_Ref Rev C nvrgdenuf Swap Meet 2 29th January 2010 07:37 PM
Copyright 1999-2017 diyAudio
