My_Ref Fremen Edition - need help on PCB evaluation - Page 12 - diyAudio
Old 30th November 2011, 07:12 PM   #111
Reality first!
ClaveFremen's Avatar
Originally Posted by soongsc View Post
Even though that might be true, but even a hanging open circuit with only one end connected could effect the sound. That is why the "ground side electrons" thing works.
Both ends should be disconnected...
It seems you could still move the limiter to the right.
I thought you asked me to make some more distance between the limiter and the compensation network...
No problem, it's even better.
I wonder if it's a good idea to have the resistor heat sink against the cap, and also it seems that the real heat sink would interfere with the OUT connector because the relation between the legs and the heat sink is different. What might be a way to solve it is rotate the resistor clockwise by 90 deg and rotate the heat sink counterclockwise 90deg and correct the relation between heat sink and resistor leg. This will give you more room around the OUT connector.
I'm not sure that I've understood correctly but I'll give it a try.
Dario
ClaveFremen "Bailando Salsa en el Sietch"
Old 30th November 2011, 09:57 PM   #112
Reality first!
Like this?
Dario
Old 1st December 2011, 12:38 AM   #113
soongsc is offline soongsc  Taiwan
soongsc's Avatar
that's the general idea, just check and see if the clearance around the OUT connector is enough to plug in the thick wires normally used.
Hear the real thing!
Old 3rd December 2011, 12:21 AM   #114
Reality first!
Default Bigger PCB
I've managed to buy Eagle Hobbyst Edition so I've made a bigger layout (100x100mm).
Now is all more spaced and 'relaxed' and more components are through hole and there is room to use a screwdriver to fix LM3886 with caps mounted...
Any opinion is welcome
Dario
Old 3rd December 2011, 08:52 AM   #115
soongsc's Avatar
Are all the surface mount components on the same side of the PCB?
Does Eagle PCB allow smooth turns in the traces and teardrop pads?
Old 3rd December 2011, 12:45 PM   #116
Reality first!
Sure, on the bottom one.
Smooth turn yes, teardrop pads no, unless you draw them manually on each pad.
Do you think that smooth traces are better? Why?
Dario
Old 3rd December 2011, 12:55 PM   #117
soongsc's Avatar
I don't have any data to prove it. But the more current flows though a wire, keeping smooth traces seems to reduce any reflected energy. Same as water flow or acoustic waves. It usually is not the most important issue, but if you can put that in conveniently, it's better to do so.
I would also still recommend trying to move the limiters away from the OUT path.
Old 4th December 2011, 02:06 AM   #118
Reality first!
Ok, I've made a 'rounded' version... how it looks?
This time I'm attaching some Eagle3D render so people could have an idea of the SMD parts...
Dario
Old 4th December 2011, 05:02 AM   #119
soongsc's Avatar
Looks great. FYI the TP Rev C board is a good example of smooth routing. I just opened up my ref C to do the compensation mod you PMed me.
Old 4th December 2011, 05:10 AM   #120
Dario,
Looks like you have already got a good grasp of this software, and I'm impressed. The design is looking really good for ease of building because it is much less cluttered than your previous attempts.
Now that the board is bigger, is there room enough to lay the resistors near the regulators down instead of standing them upright? Can you make a little more room around the 318? It looks pretty tight for the caps nearby.
Perhaps some of the traces with large radius should be straightened again to make the path shorter. I'm not sure what is really gained by using such large curves, but I think a shorter path is always better. Other than extra length, I do like curves.
Peace,
Tom E
Hx-Home Edition and Hx Mini Edition will be released December, 24th destroyer X Solid State 56 23rd May 2017 11:59 AM
MY_REF technical description mauropenasa Chip Amps 14 2nd December 2016 12:40 PM
My_Ref RevO ClaveFremen Chip Amps 52 22nd September 2011 06:07 PM
ARC Power source+Marantz 7C(PCB edition) gxcnabin Tubes / Valves 35 16th April 2011 05:01 AM
WTB My_Ref Rev C nvrgdenuf Swap Meet 2 29th January 2010 07:37 PM
Copyright 1999-2017 diyAudio
