| Chip Amps Amplifiers based on integrated circuits |
#101 |
What is of more importance to you?
That it is all on one PCB making it easy to assemble and package with virtually no wiring. or That it appeals to many other Members. I doubt the two are compatible. |
#102 | |
Reality first!
But if I must separate the PCB I think it's better to dump the DC protection that it's easier to replace with kits available from eBay or with a custom designed PCB that can accomodate DC protection for both channels rather than spread the virtual ground between two boards...
Dario ClaveFremen "Bailando Salsa en el Sietch" - My_Ref Fremen Edition GB Second Run |
#103 |
Didn't you already get all of it on there? I though it was just a matter of shifting things around. Seems to be a three partition board, power supply, small signal and high power with protection. Hmm I have not used Eagle PCB, maybe I should give it a try.
Hear the real thing! |
#104 | |
Reality first!
The only way I found so far is the full PCB (0.9.8). BTW I'm confident this complete configuration would fare well, the 'U' shaped radiating area could be a false problem... In fact in the little 'U''s branch under half of the LM3886 no important currents should flows. The LM3886 GND pin is only a reference ground for the mute circuit... Give a look at the attached zoom picture and help me determining if important currents radiates. Would that currents be lower if the ground plane under the LM3886 is removed?
#105 |
I think most current are going to come from the V+ V- lines through the output 0.47 ohm resistor to the speakers. The OUT line being so close to the LM318 probably is not the best. So what I think is that, on your schematic, anything that is left of the limiter zener should be as far away from the high current section because the LM318 gain is high. All components feeding the inputs should be furthest away. It seems that if the LM3886, c1, c2, c4, 0R47, OUT terminal are moved a bit to the side, they can be further away from the LM318 loop (are those surface mount resistors or limiter diodes beside the OUT trace?)
#106 | ||||
Reality first!
nFirst of all thanks a lot.
![]() Quote:
I could rotate R3 at the expense of a much longer feedback but distance wouldn't change much. And/or I can reduce C4 size back to 7.5mm lead spacing gaining 3mm to move R3 toward LM3886. The original TP layout (excerpt attached) it's not much different in this regard but, obviously, one of my goals is to design a better PCB. ![]() Aren't they? Quote:
It could be possible reducing C1, C2 size back to 10mm diameter gaining 0,5 cm. But it's worth it? Quote:
PS Rereading the post I see now that some minor component moving is possible... stay tuned... thanks again!
Dario ClaveFremen "Bailando Salsa en el Sietch" - My_Ref Fremen Edition GB Second Run Last edited by ClaveFremen; 29th November 2011 at 12:33 AM. |
#107 |
Got out my magnifying glass, D1, D2, and the zener are too close to the OUT. If the component/trace runs perpendicular to the high current trace, then it is less effected. Also, field strength reduces by the square with distance.
You can decide where to put you name after the layout is complete.
Hear the real thing! Last edited by soongsc; 29th November 2011 at 12:59 AM. |
#108 | ||
Reality first!
#109 | |
Reality first!
Take in account that unless Vpp on limiter is higher than 28V that circuit should behave like an open circuit.
#110 | |
I wonder if it's a good idea to have the resistor heat sink against the cap, and also it seems that the real heat sink would interfere with the OUT connector because the relation between the legs and the heat sink is different. What might be a way to solve it is rotate the resistor clockwise by 90 deg and rotate the heat sink counterclockwise 90deg and correct the relation between heat sink and resistor leg. This will give you more room around the OUT connector.
| Hx-Home Edition and Hx Mini Edition will be released December, 24th | destroyer X | Solid State | 54 | 3rd September 2012 03:44 PM |
| My_Ref RevO | ClaveFremen | Chip Amps | 52 | 22nd September 2011 06:07 PM |
| ARC Power source+Marantz 7C(PCB edition) | gxcnabin | Tubes / Valves | 35 | 16th April 2011 05:01 AM |
| WTB My_Ref Rev C | nvrgdenuf | Swap Meet | 2 | 29th January 2010 07:37 PM |
| MY_REF technical description | mauropenasa | Chip Amps | 9 | 22nd October 2005 12:59 PM |
