My_Ref Fremen Edition - need help on PCB evaluation
Old 24th September 2011, 02:13 AM   #11
soongsc is offline soongsc  Taiwan
soongsc's Avatar
The current PCB seems to be a nice size. Is C13 really necessary? I have never used an input cap in 30 years. If the DC gain is low enough, then this space is really a waste. If someone needed it, it's easy to connect anywhere in the input line between connector to PCB with any type you want. There are so many caps that are too big to fit on the PCB anyway.
Hear the real thing!
Old 24th September 2011, 03:26 AM   #12
ClaveFremen is offline ClaveFremen  Italy
Reality first!
ClaveFremen's Avatar
In this design the C13 input cap is tightly connected with C9, it can't be omitted without impacting on bass performance.
Quite all... in fact the cap I recommend in my BOM will fit only outboard as in the attached picture:
Dario
ClaveFremen "Bailando Salsa en el Sietch" - For My_Ref FE 12th GB extra boards PM me.
Old 24th September 2011, 03:35 AM   #13
soongsc's Avatar
It's my understanding that this is basically providing additional subsonic filtering (at least that is what was also previously described in the technical explanation). If it really creates a problem, then the problem would be elsewhere and system specific.
The point is, if it has to be mounted off board for best performance, why let it take up so much PCB space? All we probably need is two pads that will allow a small cap to be mounted vertically, this way we can save space for other valuable stuff.
PS. Try moving that cap in the pic around and see whether you notice a difference in sound.
Old 24th September 2011, 08:37 AM   #14
R.I.P.
move C13 off board. And use it to connect the RCA/phono/input terminal to the PCB.
Then along side you can have a DC input socket as well as the AC input socket.
regards Andrew T.
Old 24th September 2011, 01:50 PM   #15
Reality first!
Probably it's a good idea to do it... I'll check
If I understand correctly you're suggesting to place two input sockets, one that goes directly to the input net (so the coupling cap can be completely off board) and another connnected to two pads that allows mounting a tiny onboard cap, right?
Dario
Old 24th September 2011, 02:04 PM   #16
R.I.P.
no.
Look back at Jen's Leach clone.
One of the input pins bypasses the DC blocking cap.
regards Andrew T.
Old 24th September 2011, 02:27 PM   #17
Reality first!
no.
So a 3 pin connector...
Not much different from what I wrote but I get it
Thanks, I'll take a look.
Dario
Old 24th September 2011, 03:28 PM   #18
soongsc's Avatar
Does C9 have a across it? Seems to me not, but I just want to make sure.
Old 24th September 2011, 03:37 PM   #19
Reality first!
Hi Soongsc,
it don't create any problem, simply it is part with C9 of the high-pass filter to avoid DC.
I'm thinking about it.
I've moved the cap in the past I didn't noticed any appreciable difference.
I don't get it, can you elaborate?
Or are you refferring to the black cross?
If so it's simply an handle to move the object.
Dario
Old 24th September 2011, 03:49 PM   #20
soongsc's Avatar
C9 is an electrolytic capacitor, if there is a DC offset across this cap then it's fine. If not, then I was thinking about changing it to an bipolar type electrolytic and add a bypass cap to improve it's linearity. I probably should also try it on one of my chip amps too.
My_Ref Fremen Edition - need help on PCB evaluationHide this!Advertise here!
Hx-Home Edition and Hx Mini Edition will be released December, 24th destroyer X Solid State 57 1st June 2017 05:05 PM
MY_REF technical description mauropenasa Chip Amps 14 2nd December 2016 12:40 PM
My_Ref RevO ClaveFremen Chip Amps 52 22nd September 2011 06:07 PM
ARC Power source+Marantz 7C(PCB edition) gxcnabin Tubes / Valves 35 16th April 2011 05:01 AM
WTB My_Ref Rev C nvrgdenuf Swap Meet 2 29th January 2010 07:37 PM
