Old 21st September 2011, 03:26 AM   #1
Default Should tripath pcb be grounded to metal case ground?
I installed my amp which is similar to this one on Ebay.
2*15W @4? Tripath TA2024 D-class Audio Amplifier Board | eBay
I mounted it with four brass studs which grounded the PCB to the metal case. Inside this same case is a power supply with an earth ground.
The RCA inputs on the board are now grounded to the case through the pcb studs. It works great connecting my cd player directly to the RCA inputs but it sounds terrible when going through an ALPS pot connected before the RCA inputs. I mounted RCA jacks on the back of the case to the pot and to the RCA jacks on the amp. The RCA jacks on the back of the case are isolated from the case. I wondered if the PCB ground is what's wrong.
Old 23rd September 2011, 02:13 PM   #2
I've decided to leave the volume pot off the amplifier and use the volume level control for the headphone jack of my Sony CD deck. I still don't know if i should isolate my amp pcb from the metal case. Ithink i'll isolate it just to be safe.
Old 23rd September 2011, 02:23 PM   #3
N-Brock is offline N-Brock  United States
N-Brock's Avatar
I'd recommend isolating it from the PCB, but connect the case to earth ground.
Grounded, Floating, or Thermistor-To-Case for Center Tap luvdunhill Tubes / Valves 6 21st October 2008 09:22 PM
ASC metal can polypro caps: ground the metal can to AC ground? jarthel Tubes / Valves 10 6th September 2006 12:54 PM
Case grounded or earthed akunec Chip Amps 9 24th January 2005 03:49 PM
Case and metal working Vikash Chip Amps 168 7th September 2004 10:24 AM
Page generated in 0.06863 seconds (69.00% PHP - 31.00% MySQL) with 10 queries
