Old 13th September 2011, 10:40 PM   #1
Al1B is offline Al1B  Iran
Default PA100 (x2 LM3886) 0.1% Resistors
i use this schematic ....
as you can see, there are some 0.1% & 1% resistors used ...
can any1 tell me, what's the difference between using low-toleranced resistors or using normal 5% resistors?
thanx already
Old 13th September 2011, 11:39 PM   #2
nigelwright7557's Avatar
In this application the 0.1% resistors are setting the gain through the two amplifiers.
If they were mismatched by much then the two amps would be outputting different voltages and clashing.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 14th September 2011, 12:15 AM   #3
! is offline !  United States
Using less than 0.1% tolerance resistors is less than ideal, but they are used even on the audio input and certainly many people don't use 0.1% there. I usually split the difference, when I buy parts at places like digikey I notice either volume savings or a minimum # purchase requirement to buy 10 or more of things like resistors so I'll buy 10, or 20, etc, and where I want better than 2% (+-1%) tolerance between two resistors I'll just match them myself. Often the "match" won't be within 0.2% but it'll be enough to satisfy.
Old 14th September 2011, 12:19 AM   #4
Speedskater's Avatar
It's not that the exact value is so important.
What is important is that all the resistors have the same value.
Kevin
Old 14th September 2011, 12:41 AM   #5
so is there any chance i can use multi-turn variable resistors instead the 0.1% resistors (except the two 3W resistors in output) ?
Old 14th September 2011, 01:15 AM   #6
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via MSN to abraxalito Send a message via Yahoo to abraxalito Send a message via Skype™ to abraxalito
Yes, you can use a multi-turn pot to set the gain accurately. But don't use the pot to give the whole resistance value or stability will be an issue. Ideally you'd have an 18k 1% and a 5k pot in series for setting the gain. You only need one pot - its the relative gains not the absolute which is important.
This schematic has a few flaws - the main one being the matching at LF depends on the tolerances of the 100uF capacitors - better to take their tolerance out of the equation by increasing their value to 1000uF. They don't need to be 50V, 16V is fine. The input resistors R2 & R6 don't affect the gain so have no need to be 0.1% - save money on these and also on the output resistors (R10,R11) which can be 5% types. Better to be on the safe side by increasing the output resistors to 0.22R - it makes the matching of gains less critical.
I think ideas are what you want to get rid of. I don't really like songs with ideas. - Leonard Cohen
Old 14th September 2011, 09:00 AM   #7
panson_hk's Avatar
Increasing the e-cap to 1000 uF also avoids its non-linearity (distortion) occurring in the audio band.
Old 14th September 2011, 11:51 AM   #8
abraxalito thanx for ur complete reply
Old 14th September 2011, 10:19 PM   #9
Minion is offline Minion  Canada
Just use your digital multimeter and hand match the resistors to each other , if you test enough you will find pairs that are within 0.01% of each other ......
Old 15th September 2011, 12:54 AM   #10
^ Maybe my math is off but it seems as though to get 0.01% matching, even if you start with 1% resistors instead of 5%, (so there's 2% total spread possible from +-1%), you'd have to test an average of 200 resistors. For all resistors in the circuit. Doesn't seem like a fun way to spend a few evenings to me... and to get this accurate a measurement you can't really rely on just touching multimeter probes to resistor leads, you'll need a clamping contact and to pass some current through them, as in a wheatstone bridge, Wheatstone bridge - Wikipedia, the free encyclopedia
LM3886 PA100 100W Chip Amps Assembled! w/heatsink, Tested & Ready To Go! L00K :) MartyM Swap Meet 0 19th November 2010 03:16 AM
LM3886 PA100 Problem baene123 Chip Amps 53 30th December 2009 04:00 AM
Parallel LM3886 Chipamp layout (PA100) zei Chip Amps 6 11th September 2008 12:12 PM
PA100 Heat Issues...LM3886 Based..Any Ideas? MartyM Chip Amps 10 16th December 2007 11:18 PM
pa100 pcb single sided layout lm3886 dgaxeman Chip Amps 6 24th May 2006 01:45 AM
Page generated in 0.09732 seconds (78.43% PHP - 21.57% MySQL) with 10 queries
