Old 12th September 2011, 10:23 PM   #1
Default For David
David,
Sorry to take so long but I couldn't find the original files from several years ago, so I had to re-create them. No gerbers, just JPGs of the foil pattern, an X-ray view of the foil pattern, and a parts placement diagram. I used the "toner transfer method" to make my board. I also included a bill of materials for clarity. The single sided board measures 2 1/8" X 2 1/8". On the parts placement diagram which is not perfectly to scale, the decoupling electolytics are the small circles next to the LM4562, and are unlabeled. The decoupling NPO disc caps and the NPO feedback disc cap are all mounted on the bottom of the board right on the opamp pins. There's also a jumper on the bottom side of the board from pin 1 (output of opamp "a") to pin 5 (non-inverting input of opamp "b"). The circuit has a frequency resonse that is ruler-flat from less than 1Hz to in excess of 250kHz. It has extremely low THD, and noise is almost non-existent, and it sounds pretty good too.
Basic Pre-Amp BOM.txt
Mike
Old 13th September 2011, 02:59 PM   #2
CJ900RR is offline CJ900RR  Sweden
Hi.
I'm not David but this looks interesting
But, your BOM does not match up to the values in your schematic. Just a heads-up.
Old 13th September 2011, 10:31 PM   #3
Whoops, so much for clarity! Thanks for catching that, it was a mix-up from alternate versions, correct one below. I also forgot to add that C04 and R05 are baffle step correction of 3dB@480Hz (IIRC) for my particular speakers, so anyone wanting build this will probably need to eliminate them or modify the values to suit thier own system.
Mike
Old 22nd September 2011, 06:59 PM   #4
thanks! , ill give it a try!
David Ralph Chameleons Frosteh Multi-Way 36 22nd August 2011 10:09 PM
David forthharmonic Tubes / Valves 1 10th January 2011 03:19 PM
Pinging David S rick57 Everything Else 5 13th September 2006 01:51 PM
David Gammon Transcriptors Analogue Source 3 19th August 2006 03:11 PM
David and Goliath Bgt Class D 7 1st October 2005 08:02 PM
Copyright ©1999-2013 diyAudio
