Closed Thread
Old 10th September 2011, 12:35 PM   #11
Reality first!
ClaveFremen's Avatar
Default Regulators hopefully fixed, please check
I've fixed both schematic and PCB...and I've found a tiny routing error on the positive regulator, fixed.
Dario
ClaveFremen "Bailando Salsa en el Sietch" - My_Ref Fremen Edition GB Second Run
Old 10th September 2011, 04:13 PM   #12
I still don't see it.
The amplifier PSU shows only two AC connections (AC1 & AC2) from the transformer.
For a dual bridge rectifier, the transformer must be a dual secondary and each secondary has two taps/ends. I expect to see AC1a, AC1b, AC2a, AC2b, i.e. 4 tapas/ends.
That is not shown.
VR2 is still wired differently from VR1.
OK, settle for inadequate smoothing caps after you have stated that the PCB size is more important to you than your realisation that other designers have increased the smoothing cap values
the My_Evo has 10000uF smothing caps for each pump.
Old 10th September 2011, 04:44 PM   #13
Reality first!
That is not shown.
Andrew, as I've already said they're there (AC1+PGND1 and AC2+PGND2)
I do agree that names are probably wrong (in fact I've changed them as you can see in the attached updated version) but they still are the four connection you're expecting...
BTW with a different arrangement I've managed to re-implement holes for bulk wire.
Exactly, so they must be.
Please take a look on the schematic (there's also a PS detail) and point me to the error.
No, Andrew, in the Evolution there's space for four 10000uF per channel, 2 for pump #1 and 2 for pump #2.
If you have a single pump, like in the MyRef, there are only 2 big caps...
I can't really understand if you want to help or only criticize..
Dario
Old 10th September 2011, 04:52 PM   #14
That's an improvement. You have removed ground references from the secondary connection points.
VR2 is different from VR1. You have said it need be different
why?
Don't they supply the same voltage, i.e. 12Vdc?
It's possible but also the My_Evo has 10000uF smothing caps for each pump.
The PCB is already tight and full with 30mm caps, in this moment I can't imagine how to stretch in 35mm ones (and bigger value caps are mostly 35mm...)
Maybe I can't read, but I interpret your statement as: Two 10mF need two 35mm diameter footprints, but I only have 30mm diameter spaces available, so I'll just fit smaller value capacitors.
If two pumps need four 10mF, then why should one pump get two smaller capacitors? This does not make sense to me.
Old 10th September 2011, 05:22 PM   #15
Reality first!
That's only a different components arrangement and more clear naming, schematic is the same...
VR2 is different from VR1. You have said it need be different why?
Yes but one is a positive regulator the other is negative...
Take a look at the attached comparison, schematic is identical.
Obvioulsy since TL431 (datasheet) it's not a simple zener it needs two additional resistors for voltage setting.
Maybe there's something wrong?
If so please tell me what is.
No, what I've said is that, as the RevC PCB, mine has space for two 30mm smoothing caps so 2x 10000uF 63V is the maximum (and suggested) value.
Bob was asking if there is need for caps bigger than 10000uF.
2 per 10000uF are plenty for the MyRef... and hundreds of kits, including yours, perfectly works with those caps.
Dario
Old 11th September 2011, 01:54 AM   #16
R29 and R30 should be swapped to get correct voltage
Old 11th September 2011, 11:21 AM   #17
Reality first!
Yep!
Right, thanks Amycheng
Andrew, probably you were pointing the same error... just be a bit more clear next time, it was not wired differently, it was wrong , thanks
I've attached the fixed schematic and PCB.
BTW, adding an elco parallel to R27 and R29, according to this article should lower and linearize impedance, any opinion on it?
Dario
Old 18th September 2011, 12:19 AM   #18
soongsc is offline soongsc  Taiwan
soongsc's Avatar
Has anyone tried switching power on these?
Hear the real thing!
Old 18th September 2011, 12:50 AM   #19
Reality first!
Hi Soongsc,
not yet, I'm still in the design phase...
I've tried so far (on MyRef RevC):
- the TL431 PS (it works but I'm not sure it's better than zeners)
- different changes in the compensation scheme (all of them works)
I'm investigating some better (but simple, low component count) LM318 PS at the moment.
I've yet to try:
-the voltage limiter
-the PCB itself
Regarding the PCB I still need help on design and best practices, but so far no comments on it...
Dario
Old 18th September 2011, 02:26 AM   #20
soongsc's Avatar
I recall Mauro provided a good list on layout practices, as usual the devil is in the details. Not too long ago working on a different design, I discovered that any two components placed close together will interact with each other, due to the electromagnetic effect of the small amounts of current. So it's also a good practice to check the direction so that these sort of run perpendicular to each other.
Closed Thread
WTB My_Ref Rev C nvrgdenuf Swap Meet 2 29th January 2010 07:37 PM
Audiopulse RV10D2 REVO 10" DVC Sub skooter Car Audio 1 9th November 2008 05:14 AM
MY_REF technical description mauropenasa Chip Amps 9 22nd October 2005 12:59 PM
Yay! MAudio Revo modded for 3 SPDIF outputs MWP Digital Source 10 18th December 2004 07:54 AM
Is there a DIY coax input for M-Audio Revo 7,1? Ryssen Digital Source 0 1st June 2004 10:43 PM
Copyright ©1999-2013 diyAudio
