| Chip Amps Amplifiers based on integrated circuits |
Hello all! I used an LM386N-4 to build a small amp for my guitar. I used the typical application in the datasheet and an 8-Ohm 1 Watt speaker. When I play a note lightly the sound goes through. However, when I strum a chord or pluck loudly, the sound cuts out and wont come back until I stop all ringing notes. What is causing this?
Thannks! |
#2 |
Thanks for looking at my thread (to the 40 some odd that did), but I just figured it out.
Apparently, I needed more than a 1 watt speaker if I wanted to fully utilize +200 gain.
#3 |
If the sound cuts out completely and doesn't with a different speaker then it's just possible the speaker is faulty. It's not that uncommon for the voice coil to go intermitent open circuit when driven (it's a common fault scenario on old TV's).
The gain (200) shouldn't have anything do with it as long as you are not driving the amp into clipping... and any small speaker should work.
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
| Expectations from an inexpensive 3-way | peter_m | Multi-Way | 4 | 27th May 2007 09:14 AM |
| limiting gain for LM386N-3 | gpond | Chip Amps | 1 | 27th July 2006 03:38 PM |
| Help with LM386N-1 amplifier | Rob-israel | Chip Amps | 12 | 27th March 2004 07:41 AM |
| Isobaric 8" expectations?! | Rarkov | Multi-Way | 18 | 12th September 2002 02:41 PM |
| Page generated in 0.06680 seconds (65.65% PHP - 34.35% MySQL) with 10 queries |
