is .18uF too small for input cap? - diyAudio
Old 29th August 2003, 11:36 PM   #1
Send a message via AIM to travis
Default is .18uF too small for input cap?
i'm assuming yes. its the biggest non-polarized cap i have here. i am using this circuit for guitar, so... no matters as much. (to me?)
donuts
Old 30th August 2003, 12:00 AM   #2
OliverD is offline OliverD  Germany
OliverD's Avatar
Depends on what the signal sees after the input cap.
Typical values are no less than 1 µF.
Old 30th August 2003, 08:01 AM   #3
Electrons are yellow and more is better!
peranders's Avatar
It depends of the input impedance of the amp.
f = 1/(2*pi*R*C) => 0.18uF and 100 kohms = 8.8 Hz
How low bass do you want?
/Per-Anders (my first name) or P-A as my friends call me
PA03 LM4780 amplifier group buy, SIGN UP HERE for the group buy 0 boards left. 110 paid.
Old 30th August 2003, 10:19 PM   #4
I'm using a 10k volume pot
i put it together with no input cap. i hope i don't have to get back in there.
donuts
Old 1st September 2003, 12:22 PM   #5
So in the IGC the input impedance is 18K with 1uF result in 8,8Hz, that I think is low enough why others forum members are suggesting higher value?
Old 1st September 2003, 12:41 PM   #6
peranders's Avatar
It's about taste. If 8.8 Hz is OK for you, that's fine.
My personal taste is below 15 Hz at least.
Old 1st September 2003, 12:45 PM   #7
AKSA is offline AKSA  Australia
Hmmm.
Lowest note on a bass guitar is around 43Hz - I think.
If you are playing a bass guitar, and input impedance is 10K, then you'd want a corner frequency no more than 20Hz to avoid too much phase shift.
This would be 0.82uF, say 1uF nearest preferred value.
If you are using it for rhythym or lead, frequencies are much higher, and likely 0.18uF would be just adequate.
Hugh
Aspen Amplifiers P/L (Australia)
www.aksaonline.com
Old 1st September 2003, 12:54 PM   #8
peranders's Avatar
I didn't read so closely. I was referring to hifi. Guitar isn't very bass demanding and I'll guess you won't use a sub to your bass amp. 20-30 Hz is very good bass peformance to be a guitar amp.
Old 1st September 2003, 03:35 PM   #9
PMA is offline PMA  Europe
PMA's Avatar
In case you use 10k input pot I would recommend input cap of 4.7 uF at least. The reason is phase characteristics, that is influenced up to 10x higher frequency than -3dB low frequency limit.
Pavel
small-signal (small-power) fast switching complementary transistors Lola Luna Solid State 3 8th April 2010 08:51 PM
Input Choke Too Small dre7 Tubes / Valves 1 29th September 2007 11:35 PM
Small temp voltage on phono input-problem? trombone Tubes / Valves 4 19th January 2006 07:24 PM
Adding a 2nd input to small practice amp nfway Chip Amps 4 20th October 2004 07:53 PM
WTB SOLEN caps 8.2uf and 18uf 4 x-over prodigy Swap Meet 0 21st July 2004 03:39 AM
Copyright ©1999-2017 diyAudio
