| Chip Amps Amplifiers based on integrated circuits |
Hello all! Just looking for advice here. I have successfully completed a 1W amp based of LM386N-4 and played with it a bit to modiy gain, etc to learn what I could. I would LIKE to make an amp that I can use at gigs, etc. However, the learning experience has been almost nightmarish with SEVERAL path changes and not knowing where to go. So, I will ask a simple question (and expect complex answers as they just come with the territory). What IC should I look into to start building this project? I was something that has a wide bandwidth and fidelity. I also want it to be lou.d Mind you, this may dreaming, but I picture a 4X12 speaker cabinet....or 2....lol. And this dreaming is what's holding me back. I keep getting too complicated for my own good. I need something that uses 110V main to power it. Or....possibly a tutorial on designing power supplies to step main power down to needed voltages...
Forgive the rambling, but my wishes are beyond my knowledge and it's frustrating (As I'm sure you unerstand and have at some point experienced.)
#2 |
Banned
Read some of these to get an understanding so you know which questions you need to ask.
DIY Audio Articles Frank |
#3 |
Read Decibel Dungeon.
Read the datasheets and the application notes issued by National.
regards Andrew T. |
#4 |
Sometimes a square peg fits a round hole just fine
I second the reading of the natsemi app notes, excellent and very thorough, plus i believe they are currently the best driver chips available
#5 |
I am all for pouring over datasheets
. However, What I am trying to get a grasp of, what numbers should I aim for? What voltages, output wattages, etc will be a "safe amount" for a beginner to work with? Not being a specialist in this field (yet?), It's like me trying to pick a car having time travelled from 1492....lol
#6 | |
Banned
Electrocution Having said that, I use three LM3886 amps per box in an active three way, with active crossover, speaker protectors, transformer, power supplies (yes, two - one for +-15V), and balanced driver for bridging the woofer amp all in the bottom of the cabinet. But it is pointless you knowing all that because you won't have learnt enough about the dangers of using electricity. R.I.P. Frank |
#7 | |
#8 |
Class AB chip amps probably wont be loud enough for you.
Go for a discrete class AB design of 500 watts plus. Go for a design off DIYAUDIO as there are some internet designs that just dont work.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#9 |
Banned
Nigel,
The guy is a beginner and you want to set him loose on supply rails that would kill an elephant? OK, Cory, understood. What "gigs" are you talking about so we have an idea of what you are driving and do you have a speaker at the moment or is that part of the grand plan? Frank |
#10 |
Cory, you're wanting to build an amp running off 110V - any of them are potentially exposing you to lethal voltages. You're wanting enough power to drive speakers fairly loud, any amp capable will have power rails with high enough voltage to cause harm.
There isn't a lot to say about safety except the things which are obvious, don't go touching live circuits, shorting things with metal tools, or powering up a design without inspecting/double-checking it, and ideally do not work on such projects when tired, late at night, etc when mistakes are more likely to be made. In the end, you power it up and stand back hoping it doesn't make snap crackle pop boom type sounds. You mention "IC" but you're probably wanting not a single chip solution but rather a driver IC like LM4702 LM4702 - Stereo High Fidelity 200 Volt Driver with Mute for your dream project, but how about an intermediary project for more amp building experience first, like a basic gainclone using same parts other amp builders are using? |
| search pcb with IC tl494 or other Ic to build a smps caraudio | Ground Zero | Car Audio | 0 | 13th December 2010 04:58 PM |
| What is the difference between an isolated IC and a non-isolated IC? | DJ Exprice | Chip Amps | 16 | 20th June 2006 06:34 AM |
| Ic | CHS | Digital Source | 0 | 4th October 2004 04:36 PM |
| Page generated in 0.12259 seconds (83.68% PHP - 16.32% MySQL) with 11 queries |
