| Chip Amps Amplifiers based on integrated circuits |
#11 |
The EF buffer on/off becomes output voltage/current dependent. The output stage gain has additional changes due to this phenomenon as depicted in the figure. An additional nonlinearity is added to the output stage.
#12 |
What about a true CFP triple??? Only one 0.7V B-E drop?
I'm designing one now, it has the CFP, but the emitter of the predriver is tied to the OUTPUT through a resistor. Turned it on, but get some oscillation, but still tweaking it out.
You can call me Mad Professor, building crazy experiments in my Electronics Workshop |
#14 | |
I do like hearing that the output stage should be reuseable though. Other than ljm_ljm, the general consensus seems to be that if properly implemented this should make a serviceable amp. |
#15 |
The learning curve can be as steep or as shallow as one wants/needs.
It's one's ambition that puts on the stress.
regards Andrew T. |
#16 |
Did you actually try this?
It looks, as you say, very similar to the Self circuit but the low resistance that ties the CFP to the load means it works quite differently, I think. So I am quite curious about your results. What's the latest? David |
#17 |
Anything new?
| Bipolar/MOSFET CFP output stage | ashok | Solid State | 25 | 28th November 2010 09:31 AM |
| LME49810 W/ Thermaltrak CFP Output | BarryJF02 | Chip Amps | 6 | 13th September 2009 12:23 AM |
| LME49810 and Leach output stage. | DigitalJunkie | Chip Amps | 15 | 8th April 2009 10:56 AM |
| driver stage for CFP output. | RichardJones | Solid State | 0 | 21st April 2003 07:46 PM |
| CFP output stage - how to choose resistor | yves | Solid State | 0 | 3rd July 2001 01:49 AM |
| Page generated in 0.08900 seconds (72.03% PHP - 27.97% MySQL) with 11 queries |
