| Chip Amps Amplifiers based on integrated circuits |
hey everybody!
did anyone here make a simular circuit as link below? ??TDA7294?????????????????-????-??????? recently i would like to build an amp on 200~300W/channel and i will choose one of the following solution for this project: 1 circuit as link above; 2 parallel btl tda7293, probably 2~3 ics parallel. can anyone tell me which one worth more to do since a little shortage in fund that i can't build both. thanks.
#2 |
I can't read the text, but I would not trust that link with my life.
1pair of 1943/5200 is worth about 60W of maximum output power into a severe reactance speaker when used for domestic duty. If you can't tell what was wrong with that schematic then you should not be considering any of the multi-chipamp offerings that abound and await beginners to blow up all their attempts to copy.
regards Andrew T. |
#3 |
i can read the text but sorry about can't translate.
really, i can't tell what was wrong with that schematic, just need to build up an easy high power amp for continuing my loudspeaker project. so does anyone can offer me a scheme of a parallel bridged 7293? thanks. |
#4 |
With +/- 40V you can't get 400W into 8Ω load. The output stage bias looks wrong, too. There are 6 VBE between the two bases. If it works, it's because the 22K resistor is limiting the base current, and the beta of the output BJT isn't very high.
#5 | |
As tawen_mei mentioned we won't get 400 W 8 Ohms from +/- 40 V rails. |
#6 |
so, how to parallel 3pcs of 7293??
who can give me a circuit or a like of where to find? |
#7 | |
More TDA7293s in parallel won't increase the power output into 8 Ohm. You will need to go bridge-paralleled. Bridging is shown in the TDA7294 datasheet. Put the two circuits together on your own. If you cannot do that, you'd rather leave your hands off such a project.
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#9 |
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Great
I'm looking forward to how the results from that compare with those you've presented for the LM3886. Especially of interest is the LF response as those chips use capacitor bootstraps - a major difference with the 3886.
I think ideas are what you want to get rid of. I don't really like songs with ideas. - Leonard Cohen |
#10 | |
| EQ Circuit before or after crossover circuit ?? | abel2b | Analog Line Level | 6 | 27th April 2011 08:44 PM |
| Please Look at my circuit | skybird | Tubes / Valves | 7 | 19th December 2008 01:10 PM |
| Is this circuit ok? | krzanik | Tubes / Valves | 26 | 13th February 2008 12:51 PM |
| Trouble with speaker protection circuit (Randy Slone's circuit) | whalefat | Solid State | 3 | 13th April 2005 10:13 AM |
| and this circuit | takashi | Digital Source | 4 | 17th June 2003 12:54 PM |
| Page generated in 0.12308 seconds (83.79% PHP - 16.21% MySQL) with 10 queries |
