TDA8947J output power@12 volt supply
Old 7th September 2011, 05:51 AM   #11
sudhir kumar is offline sudhir kumar  India
To Andrew T & Johnr66
if it is so then why people are interested in so powerful car ams(called as 1000watts)?
I india i have seen many local made car stereos(inside is sanyo old la4440) and for my ears it gives very powerful sound.
Old 7th September 2011, 11:55 AM   #12
johnr66 is offline johnr66  United States
More watts is more SPL. 1000 watts is ~18db more than 15 watts. Of course it's likely the amp can't produce anything near 1000 watts, but is probably more powerful than a 15 watt BTL chip.
17 years ago, I built a 2 channel amp with a couple BTL chips to drive a DVC 12" driver in a ported box. Clean power would have been about 27 watts. It was plenty adequate for the job.
Old 7th September 2011, 05:25 PM   #13
pacificblue is offline pacificblue  Germany
Depends on the people. Some want so much power, because they believe the salespeople that tell them it's the way to go.
Others want 1000 Watts to impress their friends, without the slightest idea what the difference is between a 10 W amp and a 100 W other than the figure. Those are the usual victims that buy 2x17 Wrms amps for 20 Euros and believe the 2x1000 W PMPO print on the case is a proof of superior quality.
A few people that compete in sound-offs, need that much power to achieve 130dB+ of clean output from 20 Hz to 20 kHz to be able to win SPL competitions.
From a technical point of view you "need" that much power to drive extreme-long-throw woofers with 150 g or more of moving mass, built into too small enclosures, and playing music with significant content below 50 Hz at ear-shattering level. You may also need that amount of power, if you are a fan of big church organs and wish to listen to their lowest notes at live levels in your home.
90 % of all listeners will find that somewhere between 10 and 50 W they have all the power they ever need for home audio. A few difficult speakers may ask for more, but then it is worth considering different speakers rather than more powerful amps.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 29th September 2011, 11:13 AM   #14
I have read in the foroum that TDA1554 is better than old LA4440 but both datasheet tell that @10%THD.If the THD figure is same why one chip is better than other?
Old 29th September 2011, 12:51 PM   #15
The TDA1554 is a newer IC with much less support components needed. Ignore the stupid 10% figure. That is well into clipping. These chips will do in the 12 to 15 watt range of clean power before clipping with a 14.5 volt supply. Check the THD vs frequency and THD vs power graphs if provided.
Old 30th September 2011, 05:16 AM   #16
Thanks for reply,
but some more questions
If i have two chip amps (suppose one based on TDA8947) and another (basesed on tda1554) , if i supply them with equal voltages(14.5) and put equal load(4 ohm).will there be a difference in output power ?I think my english is not good but perhaps you are getting my point.
thanks in advance.
Old 30th September 2011, 11:59 AM   #17
Thanks for reply,
thanks in advance.
Your English seems fine to me. With the same Vs and load, the output power will be the same. In a practical test, there may be slight differences as chips can vary from lot to lot, but the difference would likely be within a watt. Since it takes 2x the power to make a perceptible change in sound (3db), you could never tell the difference.
Old 3rd October 2011, 05:55 AM   #18
to johnr66,
Thank you very much for reply.It was a practical problem for me but now solved.Actually i have a ready built tda8947 kit and i wanted to use it as a car-amp but not sure about its o/p at car battery voltage so i decided to make a tda1554q.since you told that both will give approx same o/p with above conditions so i am going to use the same tda8947 kit in the car.
thank again for reply.
Old 26th February 2014, 11:28 AM   #19
Pjfred is offline Pjfred
Can someone send me a diagram on a btl design for tda8947?
TDA8947J output power@12 volt supplyHide this!Advertise here!
12 volt power supply for tube amps caraudionut Tubes / Valves 9 27th April 2007 03:04 PM
how to build a 12 volt dc power supply? michelevit Class D 5 22nd December 2006 07:53 AM
How to use a 220 Volt power supply at 12 Volts in the car? Mr. Old School Car Audio 3 10th March 2006 12:11 AM
Suitable chip for 12 volt indoor supply Winnie Chip Amps 28 16th September 2004 09:44 AM
Power Supplies 12 Volt????? Co_Driver Solid State 3 6th May 2004 04:59 AM
Copyright ©1999-2017 diyAudio
