| Chip Amps Amplifiers based on integrated circuits |
#11 |
^ The "qualities" you want in wire aren't necessarily name brand or silver, just able to handle the current and low enough gauge, large enough diameter to be well mated to your PCB output terminals. Since the length is small I don't see a current problem but the terminal looks like it needs a larger wire for a good/long-term grip.
I noticed the electrical connection between the diode pins has no mechanical strength except for the solder itself. It is often recommended that you're not "supposed" to rely on solder alone for that, instead the connecting wire should wrap around the leads or another way is take a small piece of bare wire, like magnet wire, and lash it around them both is if it were rope tying two sticks together... if not a crimp connector. On the other hand I see it as just a bench testing configuration, if it were a finished amp I'd also worry about the short mains leads to the transformer being not so well inserted into the terminal block strip. Last edited by !; 14th September 2011 at 12:04 AM. |
#13 |
One comment, probably minor. Typically, it's not good practice to route your mains wires (even twisted ones.....) close to your audio. Do you really need to run your mains "twisted pair" to the same terminal strip you're using for your audio out/in?
#14 | ||
Right, I shall remove & insulate them.
#15 |
You must do so to avoid short circuit.
You can get hum noise if the AC mains/secondary is too close to the audio, particularly the small signal (input) section. It is also very dangerous that the mains is right next to the speaker output. |
#16 |
What software did you use for the 3d rendering?
#17 |
I've now got some strip board which I'll put the diodes & filter capacitors on & mount with spacers onto the aluminium. Can anybody tell me from experience whether the MUR860 will need small heatsinks on them for the sort of currents I will be putting through them? I've seen plenty of gainclone builds where they are left without heatsinks, so I presume this is safe?
It's just Google SketchUp. It's not particularly powerful, but for simple quick stuff like this it's ideal. |
#18 |
The diodes will not need heatsinks.
#19 |
a To220 diode in a rectifier passing 1Aac on 50% duty cycle will only dissipate @300mW.
2Aac for ~600mW. Rth s-a of ~5C/W gives Tc ~ Ta+3Cdegrees, when the rectifier is passing 2Aac continuously.
regards Andrew T. |
#20 |
Finally got around to buying some protoboard/stripboard to mount the diodes & filter capacitors on & got one into an operational state today. Sorry for the bad cellphone photo.
![]() It's hard to do a good comparison with my the class-D TC2000/TK2050 amp, which I've been using for the past few years, until I build the second monoblock, but it certainly sounds quite nice so far from 1 speaker. In particular, there is virtually no hiss whatsoever, even with my ear right up against the speaker's tweeter. Not sure if that's inherent to the LM3886 or just that there is less junk in the signal path than with my class-D amp! |
| chip amp build for tower speakers... LM1875 vs 3886... | wankski | Chip Amps | 9 | 28th October 2010 04:53 AM |
| Some more 3886 questions... | Bassterror | Chip Amps | 5 | 1st May 2006 01:34 PM |
| What preamp should i build for my 3886 GC??Tube?MOSFET?OPAMP?Bipolar?? | thomgun_lc | Chip Amps | 45 | 14th August 2005 04:27 PM |
| PC Soundcard/Multiple Channel questions... | RedShiftZ | Everything Else | 2 | 18th June 2005 02:10 PM |
| Multiple Z4 Questions | Buhl | Pass Labs | 7 | 30th July 2003 01:55 PM |
| Page generated in 0.11653 seconds (77.87% PHP - 22.13% MySQL) with 11 queries |
