| Chip Amps Amplifiers based on integrated circuits |
Hi folks,
So I have a Tripath amp board with a volume pot on it. But the board isn't in use ever it's just set to max volume inside the case. I thought I might remove it since I could use it somewhere else. Can I just take the pot out, and put a jumper across the in and out pin holes to complete the signal path again, and leave the earth pin hole? That should be the same in terms of signal attenuation going into the amp right, ie none? |
#2 |
yes
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine |
#3 |
Thanks. Thought I might as well check...
#4 |
Not exactly, you'd be leaving out the pot's pull down to ground (what you're calling the "earth pin hole"). You can remedy that by putting same value resistor (suppose pot is 50K, use 50K resistor... pot value should be stamped on the back or side of it) between input and ground.
#5 |
Why do I need to put a fixed resistor in parallel with the amplifier? That's just the same as having the volume pot at max volume. It functions ok just with jumpers...
#6 |
Because if your amp input need to be referenced to the ground (condenser or reference for the input), it will need this. Removing the pot has only one advantage is better contact for noise.
#7 |
By lowering input impedance you reduce RF noise picked up. Maybe in your particular configuration you can't hear any. Good... but it doesn't necessarily mean you never will.
#8 |
Ignore what I wrote, I see on the schematic it "supposedly" has a 10K resistor between input and ground on both L/R channels already.
| Help me remove a dual-gang pot out of the circuit!! | maglian | Subwoofers | 4 | 17th December 2011 03:45 PM |
| input capacitor remove or not in tripath t2020 | then_dude | Chip Amps | 8 | 21st September 2009 09:43 PM |
| which volume-pot for amp D? | gychang | Class D | 18 | 12th August 2009 06:29 PM |
| Sonic Impact T amp remove/bypass the volume control/pot | yama1000m | Class D | 7 | 21st April 2007 12:18 AM |
| Volume control : - pot' or pot' variable feedback resistor (gain) ? | ash_dac | Solid State | 5 | 1st August 2006 05:07 AM |
| Page generated in 0.10549 seconds (74.17% PHP - 25.83% MySQL) with 10 queries |
