Testing amp shut down
Old 18th August 2011, 07:50 PM   #11
Mooly's Avatar
No fluids in FET's
Piccys a bit blurry so can't see but baked heatsink compound sounds favourite.
Old 18th August 2011, 07:56 PM   #12
argonrepublic is offline argonrepublic  Canada
I am hoping for a short cut here. Would it be worth the time to clean and reapply thermal compound or is the FET likely shorted internally
Old 19th August 2011, 07:09 AM   #13
Mooly's Avatar
If the FET were shorted it wouldn't work at all.
tbh I think you are going to struggle with this. You would need to know first hand how what the amp is driving, how hot its getting etc. Does this fan/s cut in correctly ? Have you seen them run.
It sounds as though the amp is shutting down in response to some overload sensing circuitry...
Old 19th August 2011, 07:56 AM   #14
digits is offline digits
digits's Avatar
...or plainly being driven too hard too long. Don't believe everything you read on the box. That brown suff just looks like glue or varnish or something.
Old 19th August 2011, 01:40 PM   #15
When the amp turns on, the fan is slow. At about 15 seconds it is running faster. At about 45 seconds, fan is running full speed. I have not been able to make it shut down.
Old 19th August 2011, 05:21 PM   #16
OOPS. I am not sure what happened!
I cleaned surfaces and replaced output ICs
When I turned it on, it seemed to be running fine. Fan was running at normal speed.
There was a small spark yet everything seemed fine.
I plugged a speaker in and got a full 60hz hum. Maybe cooked speaker but that's OK
Feeling discouraged but not ready to back down.
Old 19th August 2011, 06:09 PM   #17
johnr66 is offline johnr66  United States
I would have wagered that there was nothing wrong with the amp to begin with. Probably just overloaded by a "friend" who doesn't know any better. Now this amp that worked fine is broken to be sure!
I don't mean to be rude but your in too deep. Take the thing in and have it serviced by a professional. Unless, of course, your friend doesn't mind you using it as a learning tool.
Old 19th August 2011, 07:08 PM   #18
I will never improve my skills by taking it to be serviced. Just need some help along the way
There was definitely something wrong with the amp. 30 seconds of operation and it was running fan full speed.
I have replaced the ICs perfectly with brand new direct replacements not a drop of excess solder.
New ICs are doing something that the old ones didn't do.
Now I am hoping to find out what that is.
There is more skill, knowledge and experience on this forum than in most service centers.
Unfortunately I don't have it!
Testing amp shut downHide this!Advertise here!
Amp Guts Shut Down? amc32 Car Audio 4 15th September 2009 05:01 AM
UcD amp cant shut off by pulling the tail current zilog Class D 1 5th April 2006 02:05 PM
Please Help - amp pop, shut down bonz Solid State 1 1st May 2005 12:08 AM
x-over makes my amp get hot and shut down SimontY Solid State 10 16th April 2004 05:00 PM
Adcom Amp "Whines" when shut off Whell Solid State 11 1st April 2004 04:34 AM
Copyright ©1999-2017 diyAudio
