Old 27th August 2003, 12:22 PM   #1
iceman is offline iceman  Sweden
Send a message via MSN to iceman
Default PSU/Diode question
Hi !
I've got a couple of Diodes: MUR2020 & MUR3060
I wonder wich is the best to use in my PS.
Is it alway best to use the largest/biggest ??
MUR2020:
20A
200V
95ns Reverse recoverTime
MUR3060:
30A
200-600V
35 and 60ns Reverse recoverTime
If you want to know, my amp is about 25W /ch +-25V
My transformer is:
500VA
Primary 230V 50Hz
Secondary 2 x 18 V
"Quis custodiet ipsos custodes?"
Old 27th August 2003, 12:36 PM   #2
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
One other thing to look at is the recovery characteristic. Soft recovery is normally better to avoid switching noise from the diodes. I would expect the 2020 to be soft recovery, but I don't have the data sheet. Other than that, I guess they are both suited.
Jan Didden
Old 27th August 2003, 01:03 PM   #3
Claude Abraham's Avatar
Default re: PSU/Diode question
Iceman,
It depends on the ac voltage you are trying to rectify. The peak stress on the diode is 2.83 times the rms voltage of the ac waveform being rectified. If the ac voltage is 120 volts rms, then the peak stress is around 340 volts. Allowing for tolerances, a 400 volt diode should be used. A 200 volt diode should be used only if the rms value of the ac is 60 volts or less. I hope this helps.
"We wish to reach the moon, not because it is easy, but because it is hard."
John F. Kennedy, 1917-1963, US President
Old 27th August 2003, 02:35 PM   #4
janneman's Avatar
....Claude, he said "2 x 18"...
Jan Didden
Old 27th August 2003, 04:30 PM   #5
Default Diodes
Thank you for the answer.
I would rectifie (only 2 x18) so i use the 2020.
Old 27th March 2005, 08:57 AM   #6
Gasho is offline Gasho  Croatia
Gasho's Avatar
MUR 3060 have shorter recovery time so it is little faster (letś say better) . You can use a Schottky power diodes , witch are much better for the sound character of audio electronics. Shottkyes are manufactured with max working voltages of 100V.
Old 27th March 2005, 09:38 AM   #7
It's here again - sound of diodes. Strange world .
Old 27th March 2005, 12:24 PM   #8
Gasho's Avatar
Strange world with big influence.
Old 27th March 2005, 12:49 PM   #9
If dioedes at PS have big influence on sound, something is wrong, fault isn't in these diodes.
Old 27th March 2005, 01:11 PM   #10
sivan_and's Avatar
Send a message via Yahoo to sivan_and
Gasho wrote:
WRONG !!
Have seen 600volt types ....
SivanandBalan
Diode Question betelgeuse Parts 4 14th December 2008 10:40 PM
diode question mike49504 Car Audio 9 12th November 2008 04:20 AM
Diode Question TunaFish Tubes / Valves 8 13th October 2003 11:53 AM
Diode PIV question ? thylantyr Solid State 5 28th May 2003 09:08 PM
Diode question Holger Barske Solid State 2 14th October 2002 02:44 PM
Page generated in 0.09370 seconds (77.90% PHP - 22.10% MySQL) with 10 queries
