Old 15th August 2011, 09:08 AM   #1
Default Single Sided LM3886
Hi Guys..Please check this Single layout for Me please
The Attachments include the pcb layout and schematic layout..Thanks in advance
Old 15th August 2011, 09:53 AM   #2
No smoothing caps?
No decoupling caps?
What are the functions of R3, R4, R5, C8, C9 and C10?
Will R1=15k, R6=1k and R7=20k lead to low offset voltage at the output?
C4 is no electrolytic. C1 should not be electrolytic, but if you use one, it will certainly have a smaller footprint.
Most traces are too narrow as are the spaces between the power and speaker traces.
Many traces are unnecessarily long and meandering about like drunk.
Signal traces should be as far as possible apart from power and speaker traces to avoid cross-talk.
Too many unnecessary jumpers.
Pads with no obvious function.
Arbitrary mounting holes.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 15th August 2011, 10:46 AM   #3
Huge lot discussions are already done on routing LM3886 PCB. search & read them, you will find lot of guidelines. and then refine your layout.
There is always a first time....
Old 15th August 2011, 10:54 AM   #4
separate the Signal Ground from the Power Ground.
The Power Ground includes the Speaker Return and Zobel Return and Decoupling Ground and PIN7 and Mute ground and Safety Earth (on the metal Chassis) and Zero Volts. The Metal chassis must be connected directly and permanently to the mains cable PE.
The Signal ground must include the Input/Signal Return, the Rin Return, the NFB from C3 (DC blocker) and the RF attenuator (which is missing).
What is VR1?
regards Andrew T.
Old 15th August 2011, 12:52 PM   #5
Hi guys, Thanks for replies..
I used the following schematic for my design..Im not too familiar with what some of the components do...
Ive built lm3886's before and they work fine..but for some reason, they all seem to "blow up" when I raise the volume to a certain level.
After some trials I decided to buy this board from Ebay:
LM3886TF LM3886 Amplifier Board DIY Components KIT | eBay
It Worked fine until I raised the volume again.
I dont know If the power supply is the problem, Im using the following torroid:
P042K 160VA Toroidal Transformer 0-35, 0-35 Vac Outputs | eBay
with 1000uF 50V Caps
(VR1 is a 10k Pot)
Old 15th August 2011, 01:11 PM   #6
pinkmouse's Avatar
Your traffo is too big. 35V rectified (35x1.41) gives you rails of near enough 50V, way higher than the chips are rated for.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 15th August 2011, 01:13 PM   #7
I would have thought so. I decided to look into building a voltage regulator..I was taught that zener diodes could be of some use but not really sure..
Old 15th August 2011, 01:43 PM   #8
pinkmouse's Avatar
I've never been a fan of regulating chip amps, but there are many threads here that discuss it if you search.
Al
The yet tiniest single-sided LM3886? hurtz Chip Amps 228 21st May 2012 01:54 AM
lm3886 single sided pcb ryan750 Chip Amps 20 30th March 2012 04:11 AM
Bridged LM3886 from single-sided supply ventle Chip Amps 10 16th October 2010 11:14 AM
Lm3886 single sided my first try ampimp Chip Amps 0 14th October 2010 10:08 AM
Page generated in 0.09221 seconds (79.10% PHP - 20.90% MySQL) with 11 queries
