Old 12th August 2011, 04:53 PM   #1
panson_hk's Avatar
Default LM3886 parallel
Anyone seen more than three 3886 in parallel? Make sense?
Old 12th August 2011, 05:09 PM   #2
In theory, yes, but as more amps are added it becomes harder to control output voltage offsets and current sharing. Whether or not it makes sense depends on what the design objective is.
Mike
Old 12th August 2011, 08:56 PM   #3
Makes no sense, because there are too few speakers around with 1 Ohm coil impedance or less. A few car subwoofers maybe, but they are better off with class D amps anyhow.
If it has been done, then most likely by Rowland Research. They just love bridging and paralleling LM3886s and TDA7293s by the numbers.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 14th August 2011, 01:04 AM   #4
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via MSN to abraxalito Send a message via Yahoo to abraxalito Send a message via Skype™ to abraxalito
I have four TDA2030A in parallel, but they're much lower current than 3886. Even if bridged, I reckon four LM3886 in parallel is overkill assuming the design is adequately heatsunk. If there is some other unusual constraint on the design, then 4 * LM3886 might be a goer in limited situations.
I think ideas are what you want to get rid of. I don't really like songs with ideas. - Leonard Cohen
Old 14th August 2011, 09:57 AM   #5
a BPA400 might make some sense in that each chip would not have to supply as much current into the 8ohm speaker and thus there could be some performance improvement.
But, in my view it is totally nonsensical to parallel chipamps when the LME498xx series of chip driver ICs are available.
regards Andrew T.
Old 15th August 2011, 06:05 AM   #6
panson_hk's Avatar
I think LM3886 on-chip protection is an advantage compared to LME498xx based amp. It is also much cheaper.
Old 15th August 2011, 06:17 AM   #7
abraxalito's Avatar
Yeah, both good points - a third is there's no worry at all about biassing schemes.
Old 15th August 2011, 06:34 AM   #8
panson_hk's Avatar
Mike
I experience the difficulty of DC offset adjustment among the 3886s in a x3 board. Without resorting to DC servo, I may DC isolate all the inputs of the inputs and fine tune the AC gain by multi-turn trim pot of each 3886.
Well a high-quality input film cap may cost more than the DC servo.
Old 15th August 2011, 06:36 AM   #9
How much cheaper than one LME498xx and a few transistors are four LM3886 and a bigger heatsink?
And what is it that four parallel LM3886 can drive in the permitted operating voltage range that three in parallel cannot?
Old 15th August 2011, 09:34 AM   #10
less current clipping/limiting for improved SQ.
regards Andrew T.
Parallel TDA2052 vs Parallel LM3886 for subwoofer goldyrathore Chip Amps 22 22nd November 2009 02:34 PM
LM3886 x 2 in parallel jmar Chip Amps 46 24th October 2009 03:53 PM
LM3886 in parallel Denis.BR Chip Amps 11 12th August 2009 07:16 PM
LM3886 Parallel Use Rachel Chip Amps 71 2nd July 2006 04:24 AM
Are two separate lm3886 = 2*lm3886 in parallel or bridge mode rs1026 Chip Amps 11 21st October 2004 10:24 AM
Page generated in 0.10324 seconds (77.64% PHP - 22.36% MySQL) with 11 queries
