LM3886 parallel
LM3886 parallel
Old 16th August 2011, 12:25 PM   #21
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
Originally Posted by pacificblue View Post
The delta T remains the same. Thanks to improved heatsinking the average temperature will be lower, so the peak temperature as a result of average temperature plus delta T must also be lower.
So do you think that thermal coupling is a function of peak temp rather than delta T? If not then we agree here.
The IC designer's meaning of reasonable. I quote from the datasheet.
In my estimation the suggested applications given in a datasheet are not intended as an exhaustive list. What leads you to think they are?
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 16th August 2011, 07:57 PM   #22
pacificblue is offline pacificblue  Germany
Originally Posted by AndrewT View Post
this seems to confirm that the protections/limiters are monitoring Tj and adjusting the limiting thresholds to suit the level and time of the transient.
One of the several protection circuits does. And it does so at an elevated dissipation level.
On transients, I think that what I hear is the early onset of current limited transients...
Did you try to confirm what you hear with an oscilloscope. You could compare the waveforms with the pictures in AN-898 and see which of the several protection circuits is the culprit, if any.
I chose to ignore your other two questions,
They were also rather directed at panson_hk.
I can only assume that you refer to delta T as the temperature difference between two media as in junction is at 140 C, heatsink is at 120 C, delta T = 20 K. If that is so, I agree that heat transfer is faster when delta T is higher.
Delta T in my post above refers to temperature rise due to the short term thermal time constants you mentioned as in x W of power due to a transient produce a temperature rise of delta T = 25 K. I made no relation to thermal coupling.
What makes you think that National's marketing people would not take the chance to add all possible applications to the list when every single item increases the number of possible customers for the product?
You may find more uses for those amps, use different schematics around them, bridge them, parallel them, whatever you like. I just find it unfair to blame them for not delivering extreme currents, not being able to deal with high amounts of reactance or having limited thermal coupling by people who ignore the manufacturer's recommendations on intended applications. I also find it inadequate to blame the protection circuits for doing their job. If that has an audible influence, it is a broad hint to use the amp right, not a reason to complain.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 17th August 2011, 12:23 AM   #23
abraxalito's Avatar
Nope - the context was thermal cross-coupling. I took it that delta T was the short term temperature rise over part of a cycle of the audio waveform.
What makes you think that ...<snip>
I note you did not answer my question.
Oh I agree - who is blaming them here? Cites would be useful as I haven't noticed blaming going on.
Ditto the above remark - cites for who is complaining please.
Old 19th August 2011, 06:54 AM   #24
panson_hk is offline panson_hk  Hong Kong
panson_hk's Avatar
Default Measured data
Some data are available from the test board. We can see below the THD vs power for single, two and three 3886s. The rails is +/- 25 V, no load.
From left to right: 1k, 4Ohm; 1k, 8Ohm; 20k 4Ohm; 20k, 8Ohm. We can see the clipping level is higher for parallel in particular from one to two 3886s and 8 Ohms load. We get lower THD by using an additional 3886. Will the fourth lead to better performance? We will know after I stacked the boards.
Old 19th August 2011, 08:51 AM   #25
R.I.P.
that applies to vitually all amplifiers not just chipamps.
Reducing the loading improves the amp performance. 8ohm speakers will always get a better performance out of a 4ohm capable amplifier when used with 4ohms speakers.
Similarly 16ohm speakers should allow better performance again.
Increasing the number of 3886 in parallel is a similar effect to increasing the load impedance. National datasheet confirms the 4 to 8ohm changes.
I remind users that the 3886 and others are crippled for peak current output. Any help to reduce current demand on any individual chipamp is likely to improve performance. But why bother? Just accept that the 3886 has limitations and adopt another amp more suited to higher current duty.
regards Andrew T.
Old 19th August 2011, 09:02 AM   #26
abraxalito's Avatar
If any users are interested, there's no evidence at all that the 3886 and others do not meet their specs. When I for one see such evidence presented I'll eagerly devour it. So far, there's been nothing. I recommend potential users of 3886 and similar not to hold their breath for it.
Old 19th August 2011, 03:13 PM   #27
panson_hk's Avatar
Paralleling more than three 3886 may not be necessary aimed for higher current demand. If this brings improvement, we may get better sound even the speaker impedance dip is about 4 Ohms. Using 3886 or other single-chip chipamp has the advantage of eliminating protection circuit design. I never doubt LME498xx with discrete output is much better. We just need to take care the protection.
Left is THD vs output power for 20 kHz, 4 Ohms load. 80kHz filter was employed. We almost get 0.01 % before clipping.
Right is THD vs freq for 44 W into 4 Ohms load. 80 kHz filter was employed.
Old 22nd August 2011, 07:14 AM   #28
panson_hk's Avatar
When one of the four 3886 gain is set different from the other three (18.8 vs 19.4), distortion is higher due to this discrepancy. 1% resistors with multi-turn trim pot are employed in the test board for gain setting. The figure below shows the THD vs power for board with and without gain error among the chips.
File Type: jpg THD vs freq 4Ohm 44W 80k with gain error.jpg (74.1 KB, 59 views)
Old 23rd August 2011, 02:12 AM   #29
CharlieLaub is offline CharlieLaub  United States
LM3886 parallel
Anyone seen more than three 3886 in parallel? Make sense?
This is an interesting thread for someone like me, who depends on chip amps for his active loudspeaker projects.
Not to hijack this thread or anything, but have you considered using the TDA7293 for parallel applications? The datasheet shows that it can be used in a Master + Slave(s) configuration, where only the output stage of the slaves is paralleled. This should make it possible to scale current without having slightly different input stages competing against each other. Also, you do not need the current distributing output resistors that are required for the LM3886.
I would love for you (Panson_HK) to whip up a board using 3 or 4 of these in parallel, or something that the user could build as 2,3, or 4 in parallel by adding components as needed. I have a design for a dual board with some tips on selection of components to keep the TDA7293 doing what they should, which can be tricky. PM me if you want the details.
-Charlie
Old 23rd August 2011, 03:19 AM   #30
geraldfryjr is offline geraldfryjr  United States
This is some really great info Thanks for taking the time to do this and present the data.
It has answered alot of things that I was wondering my self.
I have been Contemplating a 4xLm4780 to drive my ESL panels that are in the 1 ohm load range.
Right now I still have 5 chips and I will start with those and if it proves to perform well I can always get more of them to finish the project.
Thanks again. jer
LM3886 parallelHide this!Advertise here!
Parallel TDA2052 vs Parallel LM3886 for subwoofer goldyrathore Chip Amps 24 21st October 2013 05:50 PM
LM3886 x 2 in parallel jmar Chip Amps 46 24th October 2009 03:53 PM
LM3886 in parallel Denis.BR Chip Amps 11 12th August 2009 07:16 PM
LM3886 Parallel Use Rachel Chip Amps 71 2nd July 2006 04:24 AM
Are two separate lm3886 = 2*lm3886 in parallel or bridge mode rs1026 Chip Amps 11 21st October 2004 10:24 AM
