| Chip Amps Amplifiers based on integrated circuits |
#141 |
if you could source for custom wound toroid then by all means proceed with your multiple voltage config. maybe afterwards after the amp is built you could try and run it with different voltage to hear if there's any audible difference between running the amp at different voltages.
#142 | |
I am attaching the schematics and model in ZIP file, if some one can run this model and check it will be of great help... or guide me how to run this ![]() Bridge Amplifier schematics.zip The ZIP file includes LM3886.sub - model LM3886.sym - LTspice autogenerated symbol LF411.mod - LF411 model Bridge Amp schematic - circuit model in LTspice (Pic below) Bridge amp schematics.GIF |
#143 |
LTSpice does not work with the .mod extension. Rename the LF411 file to .sub, then you should get results. I have the LF411.sub file in the corresponding LTSpice folder and after deleting the include command, your file worked.
The LM3886 model is not realistic. All transistors in it are ideal models, and the current source values are all guessed. Especially for the purpose of determining compensation this model is not useful, because it does not behave like the real LM at high frequencies.
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#144 |
Thanks Pacificblue for trying this.
Did you notice any issue with the circuit in Spice, or it seems fine? I could not find any LM3886 model on National Website. Is there any reliable LM3886 model available to simulate this? I am still not able to run the model. I have changed the include file to (.include LF411.sub). I see something happening in status bar below (image below), but do not get the black screen with charts. Spice.GIF What is the simulation command you are using? I used .ac dec 20 20 100 |
#145 |
Yes, the file works fine.
No, there are no reliable spice models around. I used the same simulation command. In your file Spice looks for LF411/NS, which is not the same as LF411. The op amp value must be changed to LF411. I already had the LF411 model renamed to LF411.sub in my *\LTC\LTspiceIV\lib\sub\ directory, so I could delete the include command. In theory your method should work the same, provided you have the file in the same directory as the sim file. Either that or you have to state the complete directory path in the include command as well.
#146 |
Here is my try on making a proper AC model of the LM3886. ![]() U2 is the standard single pole OpAmp (LT's opamp.sub) with parameters made visible and adjusted. E1 introduces a set of higher poles. For convenience a squared 2nd order lowpass was choosen, with f0 and q selected to provide a close fit of the magnitude and especially the phase response compared to the published plot. Zout -- required to see the effect of load capacitance -- is more or less guesswork based on the datasheet (R) and some minimum assumed open-loop output inductance. A zobel was simulated, too, because it tapers the open-loop transfer a bit as well, although usually higher up and not very significant for the phase margin at the intercept with the typical 26dB closed-loop gain. |
| 6 channel amp with 3 TA2020 based amps | srinath | Class D | 4 | 12th March 2010 12:38 PM |
| Linkwitz Orion x-over pcb's 2 for 1. | Tristanc1 | Swap Meet | 4 | 26th March 2007 08:01 PM |
| Linkwitz Orion speakers | caw | Multi-Way | 4 | 25th July 2005 05:06 PM |
| 8 Channel Amplifier for Linkwitz Orion Kit | ngiachin | Chip Amps | 12 | 9th July 2004 08:13 PM |
| Has anyone built a linkwitz Orion? | Oz_Audio | Multi-Way | 17 | 15th June 2004 07:49 AM |
| Page generated in 0.10006 seconds (84.28% PHP - 15.72% MySQL) with 11 queries |
