Old 11th August 2011, 03:14 AM   #1
ttan98 is offline ttan98  Australia
Default Class A Buffer Op amp
I need a buffer amplifier that can drive a least 2 sources, Power amp and Subwoofer amp, I have a few options one is using tubes and the other using solid state discrete/op amp.
I am asking those who have some experience in using Class A the solid state op amp, namely:
BUF634
LME49600
I remember using an old LT series unity gain op amp. I cannot remember the number. Would any recommend the above op amp and why?
Thanks.
Old 11th August 2011, 03:57 AM   #2
kevinkr's Avatar
Please do not post duplicate threads to multiple forums. Most forum participants here are active across multiple forums and if your question has any merit at all it will get answered.
www.kta-hifi.net
Old 11th August 2011, 04:21 AM   #3
The main reason for multiple thread is that similar question was ask here however I could not get my answer from reading the responses.
Anyway point taken.
Old 11th August 2011, 04:46 AM   #4
jcx is offline jcx  United States
most audio power amplifiers will have very high input impedance, dominated by any volume pot at the input - 50K is a common value
A output stage is Class A for a range of loads, output V for a given bias condition
to drive 2 parallel 50 K loads to 2 Vrms requires ~110 uA - many "audio" op amps will do that without external bias or buffers
for somewhat higher I requirement op amp ouputs may be biased into SE Class A by pulling on the output with a ccs or resistor to a PS rail
Old 11th August 2011, 05:22 AM   #5
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via MSN to abraxalito Send a message via Yahoo to abraxalito Send a message via Skype™ to abraxalito
Quite possibly LT1010. As jcx handily points out, quite unnecessary if you're just driving two normal inputs.
I think ideas are what you want to get rid of. I don't really like songs with ideas. - Leonard Cohen
Old 11th August 2011, 10:56 AM   #6
What capacitance will the source have to drive?
Cable capacitance and input filter capacitance. How big?
The capacitances are likely to require more current from the source driver than the resistive parallel Rin.
regards Andrew T.
Old 11th August 2011, 11:26 AM   #7
umut1001's Avatar
Hi.My friend built a preamp by using opa627 and LME49600 in front of the F5 amplifier.And he said that he had the best preamp (he is 25 year experienced about audio and fixed thousands of preamplifiers and amplifiers)
My New and vintage capacitor store: http://stores.ebay.com/Paradise-of-H...dio-components
Old 11th August 2011, 02:54 PM   #8
there are reasons engineers use numbers, if you want to drive 50' of typical cable C in Class A with audio signals then you may want a few mA of bias - still easily within monolithic op amp capability with just a single bias R to a power supply
if you wwere bulding a professional distribution amp for a large studio or stage you might need 10's of mA and separate buffers become more attractive
Old 12th August 2011, 06:50 PM   #9
So, if I understand your question, you want to make a dual output Class A Pre-amp?
op-amp + op-amp buffer combinations eccdbb Chip Amps 2 22nd July 2011 04:13 AM
Preout / buffer op-amp yakideo Chip Amps 5 9th March 2011 08:33 AM
op-amp buffer for non os DAC AudioGeek Digital Source 2 6th November 2005 01:00 PM
Op-amp Buffer johnferrier Solid State 30 28th October 2003 05:38 PM
Page generated in 0.09669 seconds (77.07% PHP - 22.93% MySQL) with 10 queries
