| Chip Amps Amplifiers based on integrated circuits |
#21 |
Thanx for the replies. The Amp4 does look nice. It's output relay is sorely needed on the LePai. The LePai IS cheap and it scares me a little, that it could develop a DC problem and damage my speakers. The Amp4 scares me too, I've never soldered surface mount.
For my situation, I think madtecchy is right. |
#22 |
I see many builders express a fear of soldering surface mount elements. Let me suggest a simple Google search with "soldering SDM chips" provides several excellent videos on the subject. I had never attempted the task till early this year but now have had several successful builds. I also noticed the "41" site sells practice kits for $2. Give it a try - it's fun.
Bob M. "Arrange Whatever Pieces Come Your Way." |
#23 |
GY,
I'm usually a Class A MOSFET "purist" but recently completed the ChipAmp LM3886 dual-channel amp for casual listening. I'm impressed with the kit, the LM3886, and the sound it produces.There is a thread with my build posted, in case you want to look at it: My LM3886 build thread (Don't let the size of my heatsinks scare you--they are definitely overkill....!) Best of luck. The ChipAmp kit is a good place to start, for an easy build that provides very satisfying results. |
#24 |
I'd rather solder surface mount components... but I'd rather keep a stock of through hole for various reasons so that gives more flexibility in design changes and quick one-off projects as the urge hits.
#25 |
I'd like to vote for MyRefC because it will compete against your T-amp for sound quality.
And, MyRefC won't leave you wondering why people like chip amps. ![]() P.S. Did your LM1875's wear out? Last edited by danielwritesbac; 5th December 2011 at 05:52 PM. |
| Compare the sound of 6550 amp to a 6L6 amp | WBS | Tubes / Valves | 7 | 7th January 2007 12:16 AM |
| Does anyone compare phono stage both XONO & 47LABS | ANALOG GUY | Analogue Source | 11 | 1st October 2005 08:24 AM |
| Compare Crecendo and Leach Amp | swede | Solid State | 45 | 4th May 2005 08:20 AM |
| compare the Boz & Bls | billy | Pass Labs | 1 | 9th February 2003 02:09 AM |
| compare TDA7294 & LM3886 | billy | Solid State | 2 | 11th April 2002 11:02 PM |
| Page generated in 0.07593 seconds (79.88% PHP - 20.12% MySQL) with 10 queries |
