need for tda 7264 BTL circuit
Old 6th August 2011, 08:01 AM   #11
picowallspeaker is offline picowallspeaker  Italy
picowallspeaker's Avatar
It is the circuit topology ,based on how output devices work ( consequently ,on how they're driven) .
You just need the amplifier which would provide enough current to pump the driver .
Given that subwoofers work in a very narrow band , you can MAXIMIZE the power requirement ,trading bandwidth for efficiency .
Old 7th August 2011, 01:15 AM   #12
geraldfryjr is offline geraldfryjr  United States
I personally am not into Class D design although I do like the technology very much.
Class D uses Pulse Width Modulation to create an ampilfied analog signal for the speaker to opreate on.
This is very diferent From class A or AB designs wich are strictly linear in their operation.
Their are many Class D configurations to choose from ranging from IC's to discrete configurations and are typicaly over 90% effecient.
And from what I understand you can build quite a Hefty amp for pretty cheap that has very good specs.
There is a whole forum section here just for Class D operation and alot of very knowledgable people that could give you a better answer than I as to what is available and what works good.
I am mostly an analog buff but one day I will venture down the road of Class D myself.
Cheers! jer
Old 8th August 2011, 05:02 AM   #13
bigcatdairy is offline bigcatdairy  China
I am tryin to find out a proper circuit diagram, thank you all gentlemen anyway
need for tda 7264 BTL circuitHide this!Advertise here!
tda 7293 and tda 7294 help sagarverma Chip Amps 85 22nd March 2013 08:15 PM
TDA7294 in BTL ruferto Chip Amps 6 26th January 2011 12:19 PM
Preamp Circuit for TDA 7293 Bassterror Chip Amps 2 3rd October 2007 11:11 PM
ultra-BTL digi01 Chip Amps 1 16th March 2007 02:37 PM
Tda 1305 & Tda 1302 hifive Digital Source 1 10th April 2006 09:04 AM
