Old 3rd August 2011, 03:15 PM   #1
Default need for tda 7264 BTL circuit
Dear All, I would like to build a 2-ways TDA 7264 btl as amp for sub, can anybody give me a circuit sketch cos i don't know how to design.
The tda7264 will be taken off my old home theatre system, and the datasheet you can view via http://www.datasheetcatalog.org/data...ics/mXytyq.pdf
any kinda help will be very appreciated.
Old 3rd August 2011, 03:26 PM   #2
picowallspeaker's Avatar
By looking at the figure of the frequency response of the chip ,the output drops exactly from 100 Hz , so it's not a good choice for powering a sub
Old 3rd August 2011, 04:07 PM   #3
I see the output drop as you say, could you please recommend an IC or driver IC for powering a sub?
thanks in advance.
Old 3rd August 2011, 04:39 PM   #4
Me ??? I was wandering in search of a good 500 W class D amp for subwoofer duties ...
Old 3rd August 2011, 05:38 PM   #5
According to the chart the output drops less than .5db (.3db) from 100hz to 20hz.
This chip won't have any problems for sub use except that it only has an output power of 20 watts which is very limiting for subwoofer use.
jer
Old 3rd August 2011, 05:52 PM   #6
sregor is offline sregor  United States
Read the print - it says with Cin = 1uF. If you want a lower cut off frequencey, use a larger input cap. And, as previously mentioned, it is only down .5 db at 20Hz, so is not a big deal to begin with. Since the feedback is internal, would require an external circuit (phase inverter) to run bridged. Also, want to keep supply to 16V for bridged operation - think 4 ohm equivalent load for each channel when bridged into 8 ohms.
Steve
Old 3rd August 2011, 06:14 PM   #7
jer
what about to use it as a driver to drive a couples of diod or mosfets?
will it work that way to compensate it's limit in output power?
Old 5th August 2011, 01:23 PM   #8
That is a whole another topology It has been mentioned before and has been done with such chips as the LM1877.
It might be something fun to research,But if you need more power you are better off just getting a higher power chip and starting there, like the LM3886 or TDA7293 or TDA7294 or somthing.
jer
Old 6th August 2011, 07:54 AM   #9
jer
Jer:
Thanks Jer.
by the way, what's the difference between class D and class AB power sub amp?
because it seems good to use a class D power sub amp.
Old 6th August 2011, 07:55 AM   #10
AND WHAT KINDA CLASS D IC I CAN USE FOR A POWER SUB AMP?
tda 7293 and tda 7294 help sagarverma Chip Amps 85 22nd March 2013 08:15 PM
TDA7294 in BTL ruferto Chip Amps 6 26th January 2011 12:19 PM
Preamp Circuit for TDA 7293 Bassterror Chip Amps 2 3rd October 2007 11:11 PM
ultra-BTL digi01 Chip Amps 1 16th March 2007 02:37 PM
Tda 1305 & Tda 1302 hifive Digital Source 1 10th April 2006 09:04 AM
Copyright ©1999-2013 diyAudio
