Sanyo LA6500/LA6510, Can I use this for a low wattage Audio Amp?
Old 2nd August 2011, 06:08 AM   #1
Junm is offline Junm  Philippines
Junm's Avatar
Send a message via Yahoo to Junm
Default Sanyo LA6500/LA6510, Can I use this for a low wattage Audio Amp?
Good day, I'm planning to build a mini amp of around 2watts or greater in 8 ohms for my MP3 just for nite listening with small speakers(5w,8r) which I have 8 pcs of it. It so happened that i have 4 pcs of LA6500 and 4 pcs 6510 on the box and as per attached datasheets they can be used in audio. Has anybody used this power amps in audio amps?
I can't find any schematics for them, can they be used in bridge or parallel mode? and last thing is can somebody here show me schematics to do use them....+/- 15v reg Rails........thanks and hoping for your kind considerations.
Old 2nd August 2011, 02:45 PM   #2
johnr66 is offline johnr66  United States
I'd say they can be used as an audio amp. They have very limited output current (1 amp max), so don't use +/- 15 volt rails. Use +/- 8 volt rails with no less than 8 Ohm loads and you can get up to 3 watts of clean (pre clipping) power. A 2 amp 6-0-6 volt transformer (12 volt center tapped) would put you in the neighborhood for a power supply.
Old 3rd August 2011, 12:44 AM   #3
Junm's Avatar
Thanks John for your kind opinion...yes they are limited to 1A output current but what I'm planning is if these can be paralled to get at least 2A with the same +/- 15v and 8 Ohms load.
Also ,What if I do like to put current booster trannies at the output like the attached schematics, will it provide more distortion?
Old 3rd August 2011, 11:51 AM   #4
How much output power are you looking for? You stated 2 watts or greater for some 5 watt, 8 ohm speakers, so 2 to 5 watts, I'm thinking. The one IC as stated would work.
You could parallel them with current sharing resistors. You would then have a 10~12 watt amplifier. It would be much easier just to buy a couple LM1875 or TDA2050 ICs and build the amp since less than half the parts are needed than a parallel arrangement.
I can't say how well the circuit with output driver transistors would work for audio, but again if you want 15 volt rails, go with the above mentioned chips.
Old 3rd August 2011, 01:58 PM   #5
sregor is offline sregor  United States
One comment - kind of slow op amps - slew rate of .15 uV/sec - probably high distortion for high frequencies and may add problems if used as a driver. Looks like good for low powered projects and experiments, but not worth putting with expensive parts or extensive modification. Just my 2 cents.
Steve
Old 7th August 2011, 06:35 AM   #6
! is offline !  United States
^ agreed, these will sound terrible and along with the idea for more output power, it's much, MUCH better to pick a different chipamp chip.
Old 8th August 2011, 03:26 AM   #7
Junm's Avatar
I know they are not suitable for hi fi, but Datsheets says it is for hi quality audio amplifiers, Maybe in low power application they might work. I just want to put them in use for my PC speaker rather than staying in my box and buying a new chips.
Johnr66, yes 2 watts is enough for me and a single chip will do the job and by just providing adequate heatsink.
Sanyo LA6500/LA6510, Can I use this for a low wattage Audio Amp?Hide this!Advertise here!
anyone have any experiences with low wattage chip amps? AltecDarpa Chip Amps 8 22nd January 2012 04:18 PM
efficient low wattage sub woofers cone head Multi-Way 0 1st May 2011 12:39 PM
low wattage valve amps Benjamin Craig Tubes / Valves 14 30th November 2010 11:17 PM
What's the best low wattage guitar amp? ThSpeakerDude88 Instruments and Amps 40 4th June 2006 11:55 AM
Looking for a Low Wattage Amp Schematic. surf,sun&sound Solid State 15 24th December 2001 01:50 AM
Copyright ©1999-2017 diyAudio
