PA-100 oscilate with SMPS
Old 31st July 2011, 07:51 AM   #1
Professor is offline Professor  Russian Federation
Professor's Avatar
Default PA-100 oscilate with SMPS
Hi! I have found strange behavior PA-100 when i try use SMPS180QR (connexelectronic) instead of the usual PS with 50Hz transformer.
What i mesure? I mesure idle, with no load and short input, when connect usual PS, 110mA chips no heat
With SMPS i mesure 370mA and chips overheating, oscillating
I use 0.1% tolerance resistors in feedback, and 3% in out. I mesure DC offset, -2mV of each chip.
I have that problem on one channel, second channel with second SMPS180QR work well. Is this a problem of SMPS?
Some progress, i try to use second SMPS and problem not solved, i think it is not problem of SMPS
http://mymegahobby.jimdo.com/
Old 1st August 2011, 06:48 PM   #2
pacificblue is offline pacificblue  Germany
Is that schematic complete? Then the decoupling capacitors for the second LM are missing. It would be better to use two Zobel networks between the amps and the load sharing resistors instead of a single one after the resistors. It could also help to experiment with those 5 pF capacitors in the feedback loop. First try to omit them. If that does not help, try to increase their value and/or put a resistor in series with them.
If you only have that problem on one channel, then you should also look where the difference lies.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 2nd August 2011, 05:57 PM   #3
Professor's Avatar
Hi! I make a mistake when i making PCB. 50Hz power supply forgives small errors as for example crossing by components of power lines and etc. But if you want use SMPS it is necessary to consider rules of configuration of high-frequency devices.
PA-100 oscilate with SMPSHide this!Advertise here!
Req: Audio Design PA-100 schematics PierreG Solid State 3 18th December 2015 01:28 AM
Problem with parallel LM3886 (PA 100) mnturner Chip Amps 89 25th May 2010 04:05 AM
driver caps 100 watt PA rtill Solid State 1 5th October 2009 11:49 PM
bogen c-100 PA (solid state) oogared Instruments and Amps 21 28th April 2009 04:09 AM
Volume control on PA-100 amp Adam M. Chip Amps 2 13th April 2004 12:18 AM
