| Chip Amps Amplifiers based on integrated circuits |
#11 |
There is something about PSRR. Many ICs claim high figures that I do believe is justifiable. However, whenever a wide bandwidth (e.g. Jung Didden super regulator) is utilized, they noticeably sound very different and always for the better. This leads one to suspect there are interactions that PSRR does not take into account.
From an engineering standpoint one questions the need, but practice deems otherwise. The key to regulated supplies in audio is bandwidth as was known since the 80's. Hang a poor PS on a better amp and it is for the worse. By the same token, why does short wiring sound better? In theory, the few cms on a PCB should not make any perceivable difference. Judging by the gainclones being built it is obvious that many have discovered that it does and now seems the accepted norm. Everyone is still learning, experimenting and listening . |
#12 |
when i built my gainclone, i had 2 15v regulated power supplies in my scrap bin, so i decided to use these. having not heard a non-regulated supply, i cannot comment of the differences.
If it aint broke, don't fix it. If it is broke, fix it. If you can't fix it, take it apart and see how it "worked". |
#13 | |
I was thinking the same. For some reason though, all Jung-type regulators i've seen seem to have very low closed loop gain for dc and sometimes even lower at ac. As the 3875 is not stable at low gain it might not be suitable. Or maybe it can work with a lower reference voltage and higher gain? |
#14 |
amplifying a low reference might not be a good thing.
#15 | |
#16 |
I did some power testing for my dual LM3886 amp. I have non-regulated power supply. 8 parallel 33 ohm / 5W resistors were used as a load (= 4.125 ohms). I only tested one channel. I could only get 1 V p-p signal from my USB card. This was enough to get 18.9 V RMS or 55.2 p-p signal into load. This equals 86.6 Watts into one channel! The resistors soon got very hot, and i had to turn down power. The peak current was 6.6 A, still smaller than the 11.5 A current limit. There was no clipping. The ripple was 1.6 V. The supply voltage dropped from 33.0 V when idle to 31.4 V at full blast. I have 4*4700 uF capacitors on the PCB for power supply filtering and 2*24 V / 250 VA toroid transformer. The LM3886:s did not get very hot while testing.
See http://hepso/misc/Lm3886_amplifier.html for more details about the amp. |
#17 |
Banned
Has anyone got report on how regulated supply sounds in comparison to no reg supply and if it worth buying parts & building
Pedja doesn't give much info - simply says it does all he expected it to do? John |
#18 |
Thanks Ukram for posting that....I am in the middle of comparing the LM3886 and opa 549/541
#19 |
Correction: the input signal was 2V p-p (400 Hz sine wave).
And i agree that it might be a good idea to use regulator to make sure the amp chip is working at best possible voltage, to get maximum performance out of the chip. Just for this purpose a rather simple transistor circuit might be enough. |
#20 |
ukram, that's exactly what I am using and why as well. So far it works well, although I'm still assembling it (tested it without a chasis) and I'll put it through some listening tests in the next week. I just put together a zener/emmiter follower type regulator and haven't tweaked it yet, but at first listen it looks promising.
| Need Help with + _ 90-100 volt regulated power supplies | wrich22 | Power Supplies | 4 | 21st March 2008 10:46 PM |
| Regulated Power supplies | Ryder | Solid State | 44 | 21st April 2004 05:15 PM |
| FS: (2) 28 VDC 11 AMP regulated power supplies. | FEThead | Swap Meet | 1 | 2nd May 2002 04:18 PM |
| Regulated power supplies | Jason Hubbard | Solid State | 20 | 10th September 2001 08:33 PM |
