| Chip Amps Amplifiers based on integrated circuits |
#11 |
I'd go for a 2x12VAC transformer personally, as the Op-amp for the signal processing might not like +/-22V DC rails. Not seeing any regulators in here.
#12 |
nice, thanks, how do idecide which is +12, and which is -12 actually at the board?, easy to sort trans end, cheers, can't beleive the help i'm getting
#13 | |
I took a chance with saying use a 15v tranny as I spotted two zener diodes near the opamp and I'm assuming these are for regulating the supply to the opamp. Easy to check for definite though. If they are, then one end of each will go to ground and the other ends will go to pin 8 and pin 4 of the IC.
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#14 | |
The 1N4002 is just a higher rated (voltage rating) than a 4001. Makes no difference to the tranny type here.
#15 |
I have to agree with the 12-0-12 volt transformer recommendation. They are typically 25.2 volts (12.6-0-12.6) and will output between 17 and 18 volts per rail at idle (DC side of PS). With 10 watts at 4 ohm rating and the light heatsink, I can't see using higher rails.
#16 |
thanks once again for all your help everyone , will get new transformer tomorrow, and report back, hope to then uprate heatsink e.t.c and hopefully all will be well, it's an ok amp (or was!!) on the pre amp side with good clean channel and decent overdrive for originally very little money and is ideal plugged into my desk can't see the point (lack of any funds anyway) in buying anythig new and it's very small, hope to also take off dedicated pre out , onc again thanks to all for your help
#17 |
dear all,
i have built mapin 50 w maplin amplifier.when i on the power supply the transistor became very hot.please give me the voltages at transistor i means fault finding probe.thanking you |
#18 |
hi masood, yes i had the same problem when i first built these, you must recheck your soldering, and recheck power supply. they work well when built, but get a bit warm, also recheck components are in right place. i did all of the above and presto they worked,,. hope this helps
#19 |
thanks richa i shall find fault finding after some times many many thanks
#20 |
dear sir,
please help me for50w maplin amplifier .please send me the construction manuals and voltages at various pace,my preset2.2ohm does not show the ampr. trans. bd711 began to warm.thanking you |
| Sick Carver M-1.0t amp: bad caps? | sblack6 | Solid State | 1 | 7th June 2009 07:53 AM |
| Got this on this on ebay..sick amp | benny_rx_blanco | Car Audio | 2 | 8th April 2009 10:18 PM |
| New sick amplifier | Solosound | Car Audio | 3 | 5th December 2008 01:29 AM |
| My Fender 6G15 is sick | bassman314 | Instruments and Amps | 8 | 29th January 2007 02:54 PM |
| Help - Z4 sick on startup | BeaufortRalph | Pass Labs | 5 | 18th April 2005 06:50 PM |
