| Chip Amps Amplifiers based on integrated circuits |
#21 |
Yeah, I've just been looking on the Farnell website, and you can get 20nF film caps with a 2.5% tolerance very cheaply. What kind of power supply is usually used to power this kind of circuit? I'm thinking of a transformer with 2 x 0-12 outputs to give me 12 - 0 - -12 output. Then feed this into 2 x bridge rectifiers and use caps on the output for smoothing. Is this the best way or is there something simpler?
Another project of mine: (a very big one at that!) http://www.mp3car.com/vbulletin/show...5-pimping.html |
#22 |
There is no simpler way, but you should use a voltage regulator after the smoothing caps.
A transformer with 2x12 VAC will give you ~16-17 VDC, even more, when the load is low. You can also build a split supply with a single rectifier. It is also possible to add the voltage regulator to the power supply you already have and save the additional transformer, rectifier, smoothing caps, fuses, etc. You need to watch the heat dissipation then, because the voltage difference might be quite high. So you will either need heatsinks for the regulators or add a power resistor in series between the amp power supply and each regulator or cascade several regulators. The resistor is the cheapest and easiest method.
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#23 |
Thanks pacificblue, never thought of using resistors and using my existing supply. So I just worked out if I used 120ohm resistors from my 30v rails, thats a max current of .25A and 7.5 watts. 7.5 watts should be easily enough to power the active filter. So 120ohm 10watt resistors and +12 and -12 regulators seems a nice and cheap way to power the filter.
#24 |
Choose your topology first. Then choose your opamp and if need be adjust the topology.
Then choose your supply voltage to suit the opamp and to suit the maximum signal + dB signal overhead. Finally choose the regulator and transformer/supply. You may decide to use +-5Vdc to suit a low voltage rail to rail opamp or to use +-21.5Vdc with 44V opamp to maximise the signal overhead. Last edited by AndrewT; 29th July 2011 at 11:38 AM. |
#25 |
Thanks for the help once again. I'm currently reading about filters, there is a lot to learn. I'm an electrical engineer by trade and also do a lot of digital PIC stuff. Havn't really done much with analogue since college.
#26 | |
#27 |
Thanks for that. I've been looking at the LM388 and the maximum current is 8mA. 5 of these would only draw 40mA, so the 120ohm resistors should work fine.
#28 |
I don't have the datasheet but <=8mA for max current does not sound right. Is that 8mA the max spec for quiescent current? Look for the maximum output current and then add the quiescent current to get a rough idea of worst case current draw by the opamp. |
#29 |
Don't buy the LM388. It is a power amp.
For the LM833 8 mA is the max supply current at 0 V output. 85 mA appear to be a quite comfortable headroom for the output currents with all op amps working at line voltage levels into impedances of several to many kOhms.
#30 |
What op amp do you suggest for the circuit?
| What's the best setup for me? | atnaat | Everything Else | 2 | 22nd April 2010 06:22 AM |
| 3-way setup | shaunly | Multi-Way | 2 | 31st August 2005 05:30 AM |
| Gainclone humming in new setup | drfrink24 | Chip Amps | 25 | 24th May 2005 03:26 PM |
| setup | trip-wire | Everything Else | 2 | 2nd January 2003 04:30 PM |
