| Chip Amps Amplifiers based on integrated circuits |
Hi there,
I want to build a simple amplifier to go inside a subwoofer and i was wondering if anyone had a diagram of a circuit that uses minimal parst and can be built on strip board, this will be my first build so i don't really want anything too complicated but i am not afraid of soldering and testing things,I just want a nice simple amplifier based on the TDA2030 or an RCA4558 or TBA820, any advice appreciated many thanks Jonny |
#2 |
Hi, The TBA820 is a low power (2 watt) chip and needs a lot of parts to make work. I don't know what an RCA4558 is (some old obsolete chip amp, I guess). I'd use the TDA2050 as an easy first project with few parts and good output.
How big is your sub? Will the signal feeding the amp contain only low frequencies for the subwoofer or does it require filtering to remove the high frequency signals (sounds)? |
#3 | |
Thanks for the reply pal jonny |
#4 |
The 4558 is a low power dual opamp that would drive headphones at best
![]() This may not sound much help but the chips you mention can be very problematic in a DIY set up. They need extreme care in physical layout and wiring so as to be fully stable. They seem like the easy option... often they are not. Best bet is to base one on a proper available PCB or kit.
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#5 |
Hi Jonny,
If you bought LM3875 or 6 and used the data sheet diagrams: http://www.national.com/ds/LM/LM3875.pdf You wouldn't even need any strip board, just point to point like this; ![]() Add a Zobel across the speaker terminals [as in the single supply diagram] and a 10k pot as a volume control. Jim |
#6 | |
#7 |
Hi Jonny,
If you go to Fig 2 in the data sheet, you will see Rin 10K this is the volume potentiometer or variable resistor, then find Rsn and Csn 2.7 Ohm and 0.1 uf these two items form the Zobel network. Cheers - Jim |
#8 |
I have a little stereo amp that I made using two TBA820m chips. I used the datasheet schematic with a dual 10k volume pot on the front end. I have it in the front room with a sony walkman or an ipod and it drives a vintage pair of morduant short floorstanders. Hardly an "audiophile" setup and granted it's a different application than yours but guess what? I love it. It makes me smile, it costs peanuts and you can build an amp the size of a matchbox that'll make enough noise to upset the neighbours. Give it a go. |
| 2.1 TDA2030 amp from ebay | eladmi | Chip Amps | 25 | 30th May 2011 04:29 PM |
| TDA2030 as op-amp | pra3718 | Chip Amps | 3 | 18th March 2010 10:49 PM |
| 200w Tda2030 Amp - Need Help ! | Mx | Chip Amps | 12 | 20th June 2007 02:39 PM |
| GIGA AMP TDA2030 single(or)bridge with tone control & mic | myanmar | Chip Amps | 5 | 6th February 2007 06:28 AM |
| Page generated in 0.11414 seconds (81.01% PHP - 18.99% MySQL) with 10 queries |
