Old 21st August 2003, 02:08 AM   #1
JoeBob is offline JoeBob  Canada
JoeBob's Avatar
Default Malfunctioning PSU
I get a -33V and +1.8V, so obviously the PSU isn't working correctly. Now I know it's probably either the diodes of the cap, but which is more likely? I ask instead of changing one and trying because it's quite packed in it's place and chaning either is a pain, big pain. I'm just trying to change the most likely first, thanks for any help...
Old 21st August 2003, 07:45 AM   #2
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
JoeBob, check the voltage (AC) into your rectifier bridge and also coming out of it (DC).
Then check each rail at every stage from the rectifier bridge to the pins of the chip.
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 21st August 2003, 02:34 PM   #3
JoeBob's Avatar
The transformer is fine, and I just replaced the diodes and the same problem is there, could the caps be the cause of this problem? I don't see how it could only have 1.8V for the + voltage...
Old 21st August 2003, 03:24 PM   #4
Nuuk's Avatar
It may help us to help you if you posted what results you have at each stage of the PSU.
Old 22nd August 2003, 05:42 AM   #5
JoeBob's Avatar
You see, that's what's weird, everywhere I get 1.8V,.
Old 22nd August 2003, 06:23 AM   #6
Greg Erskine's Avatar
Hey JoeBob.
We need a little more information. Can you describe what you have done!
My first guess is you have connected up the secondaries incorrectly.
Greg Erskine
TRemPre malfunctioning Digidoo Tubes / Valves 0 27th November 2007 02:00 PM
Marantz CD63SE malfunctioning Bill Fitzpatrick Everything Else 3 24th April 2005 01:55 AM
malfunctioning voltage regulator? rkc7 Parts 4 12th August 2004 11:55 PM
Page generated in 0.09040 seconds (75.01% PHP - 24.99% MySQL) with 10 queries
