LM3886T , How to drive a big load?!
Old 9th July 2011, 12:16 AM   #1
epilot is offline epilot  United States
Default LM3886T , How to drive a big load?!
Hello guys.
I just need help please.
I have 2 questions as bellow:
I have several LM3886T amplifier chips. The first question is how can I use one or more of them so that drive a 1 ohm load?
The other question is that if I bridge them then what would be the Minimum of drove load?
Thanks a bunch for any help
Old 9th July 2011, 12:38 AM   #2
! is offline !  United States
There is a graph in the LM3886 datasheet showing approximately 18W power output at slightly over 2 ohms. You can parallel two of them to double that, but they really aren't suited for 1 ohm load, why not use different speakers instead and use your LM3886's to build a few amps that drive typical speakers?
Old 9th July 2011, 12:53 AM   #3
visioninscience is offline visioninscience  United States
Yes, this Overture Series IC can be configured with 4 in parallel for 1 ohm applications. See Page 2 in section '3.0 Conclusion'.
http://www.national.com/an/AN/AN-1192.pdf
As far as normal bridging goes with these, you can only bridge up to 2 devices and the load impedance needs to be 8 ohms.
Or, you can mix the bridge and parallel configuration, bridge 2 ICs, parallel 2 ICs, to be able to drive 4 ohms. Regardless it's all on that data sheet.
Old 9th July 2011, 01:46 AM   #4
Michael Bean is offline Michael Bean  United States
Michael Bean's Avatar
What specifically are you driving, multiple drivers in parallel? If so, it would make more sense to wire them in series, or if it's whole speaker speaker systems with passive crossovers, just use one chip amp per system. A one ohm load is going to be tough on just about any amp.
Mike
Old 9th July 2011, 01:57 AM   #5
Oh yeah, for the second part of your question, when you bridge amps, you must de-rate output capability by a factor of two, so an eight ohm load effectivly becomes a four ohm load. So to drive a one ohm load in bridge mode you would need to parallel four amps on both sides of the bridge for a total of eight per channel.
Mike
Old 9th July 2011, 02:18 AM   #6
Whoops, my stupid old brain didn't do the math right, to drive a one ohm load in a bridge, which is the same as 1/2 ohm single ended, you would need eight amps per side for a total of sixteen per channel. I don't think you want to go there.
Mike
Old 22nd July 2011, 05:20 AM   #7
eccdbb is offline eccdbb  United States
What is the desired power output? Describe your PSU specs.
+/- 30V PSU could deliver...but 30A is well....dang. Expected power ~900w into 1ohm. Need more?
Old 22nd July 2011, 10:52 AM   #8
Well done. Our questions have driven this Member into oblivion.
I really mean "well done". Simple logical thought has shown him the error of his idea.
regards Andrew T.
LM3886T , How to drive a big load?!Hide this!Advertise here!
How to choke load for big voltage swings? SpreadSpectrum Tubes / Valves 16 29th August 2010 10:13 PM
CS4397 or WM8471 can drive what impedance load? regal Digital Source 4 26th June 2008 06:38 AM
Using BOZ to drive a 20K load. G Pass Labs 5 9th July 2004 04:26 AM
Bridged and Parralleled to drive two ohm load Matttcattt Chip Amps 18 2nd February 2004 09:58 PM
Can TDA7370 drive 2ohm load? Dxvideo Chip Amps 5 14th January 2004 10:32 AM
