diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Chip Amps (http://www.diyaudio.com/forums/chip-amps/)
-   -   Tda7294 (http://www.diyaudio.com/forums/chip-amps/19198-tda7294.html)
Angel Puerto 20th August 2003 04:48 AM
Tda7294
I am interested in carrying out an integrated amplifier, I don't have a lot of experience in these amplifiers, I was thought of the one TDA 7294.
I have all the parts of the amplifier lists, alone I lack to determine
Chip Amp.
Thank you.
Angel.
Raka 20th August 2003 06:20 AM
Hola!
The TDA is the one Linn uses for it's amps, I think. I've heard that some compared it to the LM3875 and was worse, but I don't think it will be a bad chip.
Which schematic?
MCLL 20th August 2003 08:57 AM
http://www.keces.com.tw/~korping/diy...7294ia_c4s.jpg
Sound Not Bad...:) :) :)
Cradle22 20th August 2003 09:03 AM
Hi!
The TDA7294 is (despite of its higher number) outdated. Try TDA7293 instead. It is the newer and evolved successor to the TDA7293.
Ulrich Böhmke (an electrnics designer who has designed amps with TDA7294 and 7293 for Elektor and Schuro) says that one should not use TDA7294 any longer, the difference was quite notable.
Bye,
Arndt
Bricolo 20th August 2003 09:26 AM
Originally posted by Cradle22
Hi!
Bye,
Arndt
And the TDA7294S is even newer ;)
Angel Puerto 21st August 2003 02:00 PM
TDA 7294
Thank you for your comments.
Greetings.
Angel.
Angel Puerto 21st August 2003 02:08 PM
TDA 7294
Hello Raka,
I don't have resolved the circuit, I thought of the one recommended for the maker.
A greeting
Angel
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
