| Chip Amps Amplifiers based on integrated circuits |
Excuse me if this has already been answered, however, I am new to the forum.
With an AC power lines wired, you have the following: AC GND AC Usually, when wiring these to an adjustable or gainclone power supply, you connect one AC main to the fuse, and the fuse to the transformer, and the other AC main to the transformer (both x-fromer connections are usually black, eh?) Where is the ground from the AC mains best wired to? I am thinking that it should be (on a positive/negative supply) wired to the reference point between the positive and negative voltages on the supply. Is this correct? Thank you in advance for your help with this wiring. ![]() Happy Trails! |
#2 |
No, wire it to the chassis. This is normally done by soldering or attaching to a lug or bolt which is threaded through the chassis.
#3 |
There is an excellent guide to all things chip amp here.
Building a Gainclone chip amp power supply. Hope it helps. John |
#4 |
#5 |
Thank you all for your fabulous responses.
I will wire the Earth Ground to the chassis via a lug. Also, I will read the entire gain clone construction manual, and hopefully that will help me foresee future dilemmae such as this one and answer a few lingering questions. You are all fantastic! Happy Trails ![]() David Daniel Graham |
#6 |
add this to your reading list
Audio Component Grounding and Interconnection
regards Andrew T. |
| how do you connect the ground of power supply to the plug of ac ???? | prorms | Power Supplies | 11 | 24th April 2008 12:13 PM |
| ground wire very close to ac wires | jarthel | Parts | 4 | 21st April 2007 12:25 PM |
| power supply choke with a connection for AC ground? | jarthel | Tubes / Valves | 4 | 16th March 2007 10:10 PM |
| ASC metal can polypro caps: ground the metal can to AC ground? | jarthel | Tubes / Valves | 10 | 6th September 2006 12:54 PM |
| AC 120V, neutral, hot, ground | zxx123 | Tubes / Valves | 6 | 20th January 2005 12:49 AM |
| Page generated in 0.08789 seconds (70.54% PHP - 29.46% MySQL) with 10 queries |
