| Chip Amps Amplifiers based on integrated circuits |
Whats the major difference between these two?
I'm very new to the diy audio scene so i don't have any idea what the data sheet specs mean. Thanks in advance! |
#2 | |
On the top of page 3 you'll find the worst case input bias current is lower for the 'B' grade, the input offset voltage is about half for the 'B' grade and the input offset current is lower for 'B'. I think there are typos on the power supply rejection spec. A call to the field engineer would clear that up. Most applications would be fine with the 'A' grade but some uses would benefit from the tighter 'B' specs. Of course the 'B' chips cost more. 'R' is the SOIC-8 package likely in tubes of 25 or 50 pieces. 'Z' means RoHS compliant. Are you sure you wouldn't find the DIP-8 package easier to work with? Anything else? G² |
#3 |
awesome! thanks!
i had one other question, what the difference between the OPA637AU and OPA637SM? and is it worth the crazy money difference? Auzentech, Inc. OPAMP Auzentech, Inc. OPAMP The AU is $70 whereas the SM is $250 Also whats the difference between the 627 and 637? according to Auzentech the 637 is better for rock music and the 627 is better for classical, but I'd like some actual user feedback if possible. Last edited by mab1376; 22nd June 2011 at 01:39 PM. |
#4 | |
#5 |
I have no idea what any of this means, all i know is how it sounds by actually trying something.
As I said I'm very very new to all of this and kinda need some guidance as to what im looking at and what these specs actually means when it comes to using it in a real component. |
#6 |
Well, if you don't know what any of this means, then I must caution you that the AD797 requires proper care and feeding -- because of its design, it's much more sensitive to lots of subtle things than other amps.
There are several good tutorials. One is Ron Mancini's "Op-amps for Everyone" downloadable from http://www.ti.com. There's also Walt Jung's "Op-amp Cookbook" or "Audio Op-amp Applications" as well as ap-notes from other analog semiconductor companies. You can probably find some college course 'class notes' (i.e., PowerPoint presentations) via google.
bel |
#7 | |
--- NAD 541/NAD 116/NAD 214/NAD 804/APC H15 |
| WTB: AD797BRZ opamp | igor0203 | Swap Meet | 0 | 28th September 2009 06:50 PM |
| Page generated in 0.10959 seconds (73.34% PHP - 26.66% MySQL) with 10 queries |
