| Chip Amps Amplifiers based on integrated circuits |
Hello all!
I'm thinking of building an amplifier with the 49811 driving mosfets. I am going to use a +-25V PSU, mainly because I'm targeting to low power consumption as well as I'm not going to need 1kW of output power... And I still want it to sound brilliant with low volume. The output power I'm aiming to is about 15-20W max. to 8ohms... The question is: Can I go without the Vbe multiplier circuit in the bias stage or will I run in to the thermal issues? Many thanks folks for all your input... |
#2 |
I think you can go without the Vbe multiplier circuit in the bias stage with 2SK1529/2SJ200 mosfet.
But you must use large bias current about 300mA. Also large THD distortion rises because 2SK1529/2SJ200 have large thermal variation. So distortion level increased. You can see national semiconductor application note AN-1645 fig. 20. Where graph with Vbe multiplier shows bias stability , which is not so good. So you can see itself. 2SK1529/2SJ200 have large thermal variation. My suggestion is , you must use renesas mosfet 2SK1058/2SJ162 for your application with resistor bias stage. 2SK1529/2SJ200 and 2SK1530/2SJ201 caracterstics are almost same. 2SK1530/2SJ201 have high voltage and currunt rating.
Vikram Raj |
#3 |
the 49811 will almost certainly not have sufficient + to - drive voltage to be compatible with either LatFETS nor to normal VertFETs.
It may work with with the low Vgs High gfs 1529/200. The 49830 is designed to specifically have sufficient drive voltage for FET outputs.
regards Andrew T. |
#4 |
Thanks for the input!
I have decided to use thermal tracking in the bias stage after all... Is it OK to use almost what ever BJT transistor in the VBE multiplier circuit? For example TIP31? Thanks again for your help! |
#5 |
bc54xb and thousands of other small signal transistors.
Or use a sot23 NPN glued to the collector leg of one power device where it exits the package. For better tracking of both output devices use an NPN & a PNP glued to both output device collectors. Then use the dual transistor version of the Vbe multiplier.
regards Andrew T. |
#6 |
Thanks Andrew for your suggestions!
It would probably be better your way, but I was thinking to make this very small and compact. This is what I have in my mind and actually have all the components for it also. Will it work? ![]() Questions: Does the component values seem OK? Suggestions for CB? Value, type? I have TIP31 for QVBE, OK? Will I get a problem, if I used Rs as the volume control at the same time? Thanks again for all input... |
#7 |
Is Cb the cap across the Vbe multiplier?
Cn seems too low. It creates an ~7MHz low pass filter. Is Rb3 (390r) in the correct place? The gate stoppers should be fixed value resistors soldered directly to the gate pins.
regards Andrew T. |
#8 | |
Cn - noted... RB3 is needed according to the LM data sheet AN-1645, but I don't know how much I can copy from there directly for this chip??? Gate resistors - noted. Can I use the values from AN-1645 (500r for P-channel and 175r for N-channel)? |
#9 |
Hello again!
Circuit updated! NOT WORKING! I believe it oscillates like crazy, or at least it consumes all power available from the PSU. No DC voltage at the output. One channel consumes 95W of power with 10k resistor (RS) at the input. With input short circuited power consumption rises to 110W (55W per rail = PSU max.) - how interesting? Is my circuit OK? Or do I have a problem with my PCB? |
#10 |
I measured the voltages at the source and the sink pins.
Voltage at the source is +2.55V, and at the sink -2.38V. OK??? |
| Toshiba 2SJ200 2SK389V dual FETs for sale | WALTER BURKHARD | Swap Meet | 2 | 17th February 2012 06:41 AM |
| FYI: Toshiba 2SK1529/2SJ200 reached EOL | zhoufang | Pass Labs | 4 | 11th May 2011 03:17 PM |
| Spice Model for 2SK1529 | EUVL | Parts | 2 | 27th July 2010 12:16 AM |
| 2sj200 ?? | B.I.G | Solid State | 11 | 23rd April 2010 06:09 PM |
| 2sj200 2sk1529 toshiba mos-fet | Sunmans | Solid State | 1 | 13th September 2009 04:53 PM |
| Page generated in 0.09766 seconds (84.38% PHP - 15.62% MySQL) with 10 queries |
