The yet tiniest single-sided LM3886? - Page 23 - diyAudio
Old 10th May 2012, 05:07 PM   #221
I have max power tested amplifiers using those fuses and find they never blow during testing.
The heating effect of music waveforms can never be as high as a max power test, so the fuses should never blow during normal and silly party operation.
For those reasons the lower value fuses using Quasi's rule may be better for even closer rating of the fuse to the duty.
BTW,
33Vpk into an 8ohm speaker can only be had from a supply around +-38Vdc. You should never build a 4ohm capable chipamp using +-38Vdc supplies.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 10th May 2012, 07:06 PM   #222
hurtz is offline hurtz  Germany
And I'd never doubt your expertise.
BTW,
That's the point, I might have missed to mention it, but I only have access to 18-0-18 toroids. So for any impedance pkV will be 25.5V. So rather than calculating with the maximum continuous power rating of the AMP I'd rather start with my pkV and impedance and look at I and P afterwards. This won't protect the AMP (with 162W peak theoretical output) but that's what spike is for anyways. And it won't blow the fuse for any power-peaks.
(I am not trying to argue experience here.)
cheers,
hurtz!
Old 10th May 2012, 09:28 PM   #223
Updated PSU with Fuse holders (microfuses):
PSU+ v2.4
Old 12th May 2012, 12:03 AM   #224
Attached you will find the PSU++ v1.0 which is intended to be used with a single toroid and 5 AMP boards for surround sound.
Each rail has 8 caps with 4700uF each, 37600uF total.
cheers,
hurtz
Old 12th May 2012, 11:36 PM   #225
I added 100nF caps accross the diodes to decrease transformer noise and potentiometers in series with the LEDs to manually set brightness.
PSU+ v2.7
PSU++ v1.1
cheers,
hurtz
Old 13th May 2012, 08:28 AM   #226
marce is offline marce  United Kingdom
Why not use copper pours (areas) instead of the serpentine traces.
Old 13th May 2012, 10:33 AM   #227
Originally Posted by hurtz View Post
I added 100nF caps across the diodes to decrease transformer noise
Are you sure this is an improvement?
regards Andrew T.
Old 13th May 2012, 11:41 AM   #228
To increase RC-filter characeristics.
Well I've read about it on esp which so far never disappointed me, and from the wiring they are optional. I hope I can measure a difference...
cheers,
hurtz
Old 21st May 2012, 01:54 AM   #229
Yet one more question about the secondary fuses, we concluded that the two secondary fuses should be ~2/1.6A for 8r0 speakers. But isn't this the calculation for just one speaker/amp?
Yet twice the ampere rating for two speakers does seem a little bit high. Maybe times sqrt(2)? (And sqrt(5) for 5? :-D)
cheers!
hurtz
Old 8th June 2012, 10:45 PM   #230
So here are some news, the latest revisions have been produced and tested. (PSU+ v2.7/AMP v6.3)
In this design the board is fully populated, including Cd with 330pF, and the new 100nF capacitors across the diodes on the PSU+.
Not included is the 47pF capacitor across the rca inputs.
Attached you will find the rmaa test charts, comparing the older [AMP v5.9/PSU+ v2.2] with the new one. Please ignore any stereo-realted data, I only tested one amp with a Y-cable (I had to use rmaa 5.5 which doesn't support mono mode).
I am glad to report that the noise level decreased considerably, also transformer noise was greately reduced and eliminated at 100Hz.
Please note that the tests were made on two different soundcards, where the "old" amp test was taken on an Asus xonar D2X and the "new" amp on a Creative Soundblaster X-fi USB. Hopefully I will be able to retest both amps on the same soundcard soon, then with added baseline of the soundcard.
cheers!
hurtz
P.s.
Please rename the .txt files into .sav to open them with rmaa.
- For there is nothing either good or bad but thinking makes it so
lm3886 single sided pcb ryan750 Chip Amps 56 27th May 2015 02:35 AM
Single sided lm3886 board, opinions? Adam Eng Chip Amps 5 26th March 2014 02:18 PM
Lm3886 single sided my first try ampimp Chip Amps 0 14th October 2010 10:08 AM
Single sided non inverting LM3886 PCB tla-Audio Chip Amps 35 1st April 2009 07:16 AM
Copyright 1999-2017 diyAudio
