| Chip Amps Amplifiers based on integrated circuits |
i`m build a gain clone.
to be specific, i`m building the inverting GC design originally done by Thorsten. IGC i`m going to build a dual mono design with 2 nuvotem-talema toroidals. they are 225va. since i`m running a 5R load. i intend to run it off 18-0-18vac. i don`t need lotsa raw power since i`m running 96dB/w drivers. the main power supply caps would be Elna`s that were made for Onkyo Systems. they are labeled Onkyo Integra. its 10,000uf @ 50v. i intend to bypass with 100uF Elna Silmics. do i need to dump in two more 0.1uF caps alongside the power rails? if so, i intend to use Silver Mica. is this a good choice? Thank You in advance REGARDS |
#2 |
Don't waste 0.1 silver micas in a PSU, send them to me instead.
#3 | ||||
Previously: Kuei Yang Wang
Konnichiwa,
Feedback Resistor 330k in all version. Input resistor 10k & 100k Linear Law Pot for "Integrated Amp". Preferred Pot types are Cermet from Vishay/Sfernice or ANY Carbon track ones, but preferably old hotmolded AB, Copal etc. - choose to taste, Cermet "precise" and "clean" and "neutral" while Carbon "musical" and "warm" and "romantic" (read a little fuzzy in a nice way). Input resistor 15k, 18k from input to ground (across the RCA). Either versions will normally be stable under all (most) conditions (integrated Amp not with open input and volume near max!!!!) of normal use. Also, it should not be subject to the audible problems remarked upon with the "brutal force stability" 22k resistor from the inverting input to ground. The Resistor in the output and the RC on the non-inverting input are "optional" and where originally added to make the circuit more tolerant of "out of spec" IC's and (highly) capacitive Speaker Cables. Quote:
Leave the 10,000uF Cap's out in the initial wireup. You can add them later (IF you must) with added leads paralleled to 1,000uF Silmics. For bypassing it is ABSOLUTELY ESSENTIAL to place the physically and electrically smallest capacitor in the shortest current loop anyway. Whenever I see a HUGE pysical side cap bridged with smaller caps having very long leads in positions other than coupling capacitors (high impedance circuits) I despair!!!! Quote:
Sayonara |
#4 |
I'm with Thorsten, 100nF Silver Micas cost quite a penny and if you know of a source for them, do tell us.
#5 | |
se |
#6 |
the 10% 0.1uf @ 100vdc is going for SGD$0.51 per piece.
the xchange rate from SGD to USD is 1.74... it isn`t to bad wad... couple of cents |
#7 | |
#8 | |
Konnichiwa,
I still recommend the Epcos (formerly Siemens) naked chip, stacked film MKT/MKC Capacitors as they offer a very "ideal" capacitor with only around 9nH Parasitic Inductance (ESL) and << 0.1 Ohm ESR in the larger values. They go up to around 4u7/63V and are physically small. For reference, the 9nH Inductance translate to around 1 Ohm impedance @ 20MHz, which is often good enough for digital decoupling on their own, no added bypass needed. Sayonara |
#9 |
its silvered mica.
is silvered mica and silver mica the same? if it is, i think we are talking about the same thing.... i found even cheaper ones. its 50vdc... its going for $0.28 the dielectric is X7 R. there is a word Kemet labed nearby, i remeber kemet having something to do with ceramic.... |
#10 | |
X7 R is ceramic, EIA code -55 to 125degC, 15% tolerance. regards |
| silver mica caps | doktor | Parts | 14 | 26th April 2006 02:08 AM |
| silver mica and pp caps | ronardi | Parts | 3 | 24th March 2005 03:06 PM |
| Replacing ceramic disc caps with silver mica caps? | G | Solid State | 5 | 18th November 2002 02:02 PM |
| Page generated in 0.22423 seconds (54.35% PHP - 45.65% MySQL) with 11 queries |
