Old 28th August 2003, 11:00 AM   #51
Electrons are yellow and more is better!
peranders's Avatar
Originally posted by hacknet
its interesting how easily it seems to get the gc to oscillate...
what causes oscillation and how do i tell if its oscilating?
Take an AM or FM radio and turn the tuning. Maybe the radio gets silent or your hear weird sounds/noise.. Then turn off your GC, the radio gets noisy again.
/Per-Anders (my first name) or P-A as my friends call me
Old 5th September 2003, 12:18 PM   #52
fedde is offline fedde  Netherlands
Send a message via ICQ to fedde
Default Re: Re: Re: Re: Re: Re: Re: Silver Mica de-coupling caps
Originally posted by Peter Daniel
I already know that BG are not ultimate coupling caps, and I don't use them at all for coupling (at home). My current choice is Siemens MKV and it outperforms any audiphile brands I was using so far (Hovland, MIT, Jensen, etc).
What value of MKV do you use for coupling !? Try to use two BG N's (4.7 uF, 50V) anti-parallel. This sounds IMHO much better than a single one. The sound is more direct and less harsh...
Fedde
http://www.fedde.nu, gainclone and non-oversampling DAC audio projects and kits...
Old 5th September 2003, 12:23 PM   #53
Bricolo is offline Bricolo  France
Bricolo's Avatar
when you say antiparalllel, do you connect the - together, or the + together?
Old 5th September 2003, 12:43 PM   #54
!? Anti-parallel is two caps parallel, but one is reversed. The BG-N is non-polar, so it does not have + and - connections. The direction of the cap can be observed by looking at the texts.
Ah, I just found a thread on Diyaudio: Black Gate 'super E' caps
I didn't read it yet, might be interesting...
Fedde
Old 5th September 2003, 01:25 PM   #55
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
I use 3.3u MKV at the DAC's output. I found them better than MIT RTX in parallel with 0.22 silver foil bypass (which was definitely better than a single BG N). Those MKV caps are particularly good in tweeter crossovers. I used them in 3 systems and simply couldn't find a better choice. The trebles are very natural and detailed without any artificial residue added by some other caps (I tried Hovlands, MIT, Jensens, Wondercaps and some other less exotic brands).
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 10th September 2003, 11:06 AM   #56
Are those 3.3 uF caps large !? Expensive !? (the caps you use for the tweeter are quite big, are these 3.3 uF too !?)
Fedde
Old 10th September 2003, 12:09 PM   #57
Terry Demol's Avatar
I already know that BG are not ultimate coupling caps, and I don't use them at all for coupling (at home). My current choice is Siemens MKV and it outperforms any audiphile brands I was using so far (Hovland, MIT, Jensen, etc). In tweeter series network it is simply wonderful. No bypassing also, as this makes things worse (even with silver foil caps). I still wonder what would be better choice for 1000u PS caps? I don't suspect that Panasonic FC betters BG. I was always thinking about checking out Nichicon Muse KZ series, but somehow didn't get to it yet. My initial testing with Nichicon Gold series indicate that they are very "soft" sounding. Somebody mentioned Silmics?
Peter,
Might be worthh checking if Jensen make 4 pole electro's
to suit GC app. I have used them in tube stuff and they
sound great. They were not harsh and over detailed
like BG but still very nice, clean and natural sounding.
Terry
Old 10th September 2003, 01:00 PM   #58
Fedde
They are large, the same as used for tweeter.
www.audiosector.com
Old 10th September 2003, 01:04 PM   #59
Default Re: Re: Re: Re: Re: Re: Re: Re: Silver Mica de-coupling caps
Originally posted by Terry Demol
Peter,
I have some Jensens 4 pole electrolytics, but they are 10,000u, not suitable for GC. I tried to attached them once to 1000u's BG I'm using currently but the I didn't like the change.
I'm also using 1000/50 BG type N caps (in my personal amp). They are listed at $80 a pc. They are also very different from standard version. Much more laid back, more refined and with better detail. Need also more time to break in, but seem to be sounding pretty good. Those supposed to be the best PS caps around
www.audiosector.com
silver mica caps doktor Parts 14 26th April 2006 01:08 AM
silver mica and pp caps ronardi Parts 3 24th March 2005 02:06 PM
Replacing ceramic disc caps with silver mica caps? G Solid State 5 18th November 2002 01:02 PM
Page generated in 0.10585 seconds (80.09% PHP - 19.91% MySQL) with 11 queries
