| Chip Amps Amplifiers based on integrated circuits |
Hi guys,
I have (yet another) LM3886 grounding question. Yep, I've read all the posts I can find on grounding this chip! I'm building an LM3886 amp, using a PCB based on the datasheet (non-inverting layout, including zobel network), with separate ground traces, and separate ground wires running back to a big central star ground. All well and good so far ;-) So, quoting the datasheet : "Return the load ground, the output compensation (zobel) ground, and the low level ground to the common ground point through separate paths." I have no problem with that, in so far as it goes. But this leaves me with two questions on grounding : 1) What do people advise for the *chip* ground (pin 7) ? Another separate return to the star ground? Tying it into the local PSU ground? Tying it into the local low level ground? 2) A less important question... is there any benefit in splitting the low level grounds into separate ground returns? Separate input and feedback? Or is this irrelevant (or detrimental)? Thanks for your thoughts! |
#2 |
According to its function it belongs to the low level ground and that is also how National reference designs deal with it.
In the low level section the advantage of short paths is bigger than the advantage of keeping currents separate. The currents there are very small so they won't lead to big differences in ground potentials even if they add up. Separate ground returns don't make much sense there, although the differences will be small either way.
If you've always done it like that, then it's probably wrong. (Henry Ford) |
| Dc 25v at pin 3 lm3886 (help) | jaffeth | Chip Amps | 6 | 25th November 2009 02:37 PM |
| PS Pin Capacitance LM3886 | Puffin | Chip Amps | 9 | 4th March 2008 01:29 PM |
| chip amp with distortion pin (?) | netrino | Chip Amps | 7 | 8th January 2007 09:55 PM |
| LM3886 Pin-7 | GarMan | Chip Amps | 1 | 13th April 2006 04:32 PM |
| lm3886 current at pin 8 | jaudio | Chip Amps | 3 | 29th December 2004 09:59 AM |
| Page generated in 0.07473 seconds (73.40% PHP - 26.60% MySQL) with 10 queries |
